Okay this is the second time this has happened and I figure that it is either something that I am doing wrong or some unwritten bug, unfortunately I am still using 4.0 as STS on 5.1 only allows 1 instance at 32 voices.
The first time this happened was a crash, if my memory serves me right, when I went back into Scope, the Master verb Pro and effects pack 1 and 2 were whining about being registered, of course i have these packages according to the allkeys, but they would not take the keys.
So I figured that in some weird way perhaps the crash corrupted a file or something so I tried to overwrite the Dev with a new Dev but that didn't work, it wasn't until I reinstalled Scope that the problem went away, but not with out it deleting my presets and all devices, including the free ones (causing a copy and paste yes and no questionnaire). Argghhh! Well, after much back and forth I was back on track.
I recently installed a fresh new copy of XP, reinstalled all scope as before and everything works fine, no issues, then I needed to install a Nanokontrol2 midi controller which required me to remove the excess midi entries in the registry as I had reached the limit, no problem, i did this on the old XP with no problems, and just to make sure that Scope Midi drivers didn't get skipped I went into the I/O enabler and reduced the MIDI ports to 4 from 5.
After that I installed the Korg Nano drivers without a hitch, cranked up Scope 4.0 and....BAM!! please register Master verb Pro and etc, WTH!!!
WinXP SP3
Intel DP35DP Motherboard
4 gig Ram
2 x Pulsar II
1 x Luna II
I can reinstall Scope and Fix the Issue, but would like to know what the issue is and how to avoid this if anyone has a solution.
thanks
p.s. Sorry for the long story, wanted to be thorough with what steps brought me here.
WTH? Plugins keep unregistering
Re: WTH? Plugins keep unregistering
the NoKeys files(oxe), when do you use these.
Funny thing is, I finally got the Protone dev to work from the oxe file while looking for a solution for the problem above, could these help to avoid reinstalling, or will I just screw things up?
One more question, is there a switch to disable the hardware driver install like /* or something?
use the v5 versions when available!
sure, if you have a crash these things can happen. files get corrupted that way. the computer is just a huge filing system. it only works if all the files are intact and where they are supposed to be.
Are you saying use the V5 dev on SFP 4.0?
no, you're doing ok.
