I have too many PCs, still have ancient GigaDAW w/ a Pulsar Project, a Wolfdale 8600 w/ an RME Card, and my i7 rig for the XITE-1.
The new rig w/ the 4U /10U Slant Mixer Case total is 1650 USD.
PRO-X4 10U / 4U 160
INTEL I7 3770k 340
SUPERMICRO CSE-813MTQ-350CB 225
ASUS P8Z77-V LX 140
CORSAIR Vengeance 8GB (2 x 4GB) 110
OCZ Vertex 4 128G 128GB SATA III x 2 360
Seagate Momentus XT 500GBSATA 3.0Gb 110
WINDOWS 7 16GB X64 100
ICY DOCK MB882SP-1S-2B x 3 70
StarTech Model EPS8EXT 8" EPS 8pin ext. 5
SuperMicro SNK-P0046P 1U Passive 25
______________________________________________
1645 USD
Hope it works....My 8U LCD with handles will go on top instead of a mixer.
XITE-1 1U ATX Companion
Re: XITE-1 1U ATX Companion
Nice, the Seagate Momentus has some of my designs in it
Cool.
I got one in the i7 DAW to replace an old WD360, their perfect for OS+Apps and Audio Storage.
- Bud Weiser
Which brand mixer case is this ? Can´t find it in the web ...XITE-1/4LIVE wrote:
PRO-X4 10U / 4U 160
Attention:XITE-1/4LIVE wrote: INTEL I7 3770k 340
Seems Intel Ivy Bridge Rev. E1 is 95TDP,- not 77TDP !
There were several different labeled retail boxes found meanwhile.
Here´s the article in german.
Sorry,- didn´t find any english equivalent.
They say it could be a fake but because there were several boxes found they think it´s not.
http://www.pcgameshardware.de/aid,87786 ... idge/News/
Could be it doesn´t work well, especially not if the Intel i7 Ivy Bridge run hotter than expected and advertised.XITE-1/4LIVE wrote: SuperMicro SNK-P0046P 1U Passive 25
Last post ...
http://www.silentpcreview.com/forums/vi ... wrapheader
Here´s the alternative,- Scythe Big Shuriken:
http://www.scythe-eu.com/produkte/cpu-k ... riken.html
You´d be able to replace the 120mm fan by any other of your choice for more optimization.
Yep, good luck and please let us know.XITE-1/4LIVE wrote: Hope it works....My 8U LCD with handles will go on top instead of a mixer.
A 1HU solution is very interesting,- OTOH,- 2HU would be more safe eventually.
http://www.ebay.com/itm/180826875217?ss ... 1423.l2649
I have an ancient old H & S Case and Anvil version too.
I have had these since we were using McIntosh 2500 Watt Tube Power Amps. Still have the power amps and they work perfectly well with their Orange glowing tubes. Bought those used in 1981.
Thanks for Ivy Bridge Tip. That will be the last piece of the puzzle and the choice of the Asus was made solely on thier parallel RAM trick which has even Intel shocked.
The X79 Qaud RAM seemed to excell in synthetic benchmarks but not in real world.
Perhaps the Asus Hyper RAM trick might work.....
I have already installed all 4 x storage devices and they kick major booty.
thing with 1u boxes. you need 1u fans. they sound similar to formula 1 cars.
True, but it shall sit at the top of the 4Us interior, thereby getting plenty of space between the slanted top, and above the CPU, Supermicro has a Grilled/Grove design that sits above the CPU. I could use the 1U HSF, but supposedly the Supermicro guy in Freemont says they run clusters of AMD Blades using Passive cooling and their wattage is twice as much as the Ivy Bridges.
The Icy Docks drives suck in air and kick it straight out the back, and the CPUs heat will rise, as an in Nature.
Fingers Crossed.
Fingers Crossed.
your xite itself makes quite a lot of heat though, and it will rise in to the computer, so your cooling is going to be a bit more complex. my xite sits by itself on a shelf, and i even raised it so air could flow around the bottom of it.
mind you i think supermicro is probably the most trustworthy of all PC companies, and if they say it will work then it probably will.
The XITE-1 also will have a space above and below on the backside of the 4U Case.
That sucker is hotter than a whorehouse on dollar day.
