Does anyone know something about setting the priority on Win 2000?
As I see in the proccess tab, Pulsar's prioriy is Normal while Cubase
priority is High.
This settings make the Pulsar software to work very slow while using
high percents of CPU in Cubase.
When trying to set Cubase priority to Normal, it seems like pulsar works fine but when closing Cubase, the priority set automatically to High again.
Whats the best priority settings for audio progs?
How to set the priority so it stay as the last setting?
						Win 2000 piority for audio programs
Cubase is one of the few programs that has user setting for that.  chk Cubase->options-> audio setup-> system.  lh lower corner, uncheck 'expert mode'.  or at least not set it to 'High'.
You could play around with these and monitor your system to find ideal settings. Normal='expert' disable, then Win2K controls the CPU priorities.
