Mix your 4 different Filters, with 4 different Oscillators and have fun with Dual Patern LFOs.
Really powerful and well designed to work a left hand 5ths type of use, while having another synth on the upper split.
							Pattern LFO's + 4 x Osc
- next to nothing
Re: Pattern LFO's + 4 x Osc
Nice one
Just a few tips to those who doesn't get instant audio-gratification, be aware the modpatch is saved to MIDI channel 3. Also, atleast here, i have to pick a preset to get any sound.
Just a heads up, and it sounds sweet
PS: I like adding modulation to the LFO freq as well, suits the beast fine
Thank you very much for sharing!
Thanks CHief.
I'm working on a Lead Bass Funk style Stevie Wonder patch now where I use 4 x Osc, and 4 x Control Smoothers that act as seperate Oscillator Glide and it sounds pretty good, will share when finished.
Modulating the LFO works well too. I can incorporate that on the Mono, but for some reason XITE-1 has DSP errors when certain Flexor Modules are used. Didn;t notic this until OI went to 48k, but since Solaris sounds so good at 48K via SP/DIF to AES/EBU I gosta stay there now....
- roy thinnes
hi JAV, nice patch!
same issue as NTN, but then, after selecting a preset:
sweetness... (preset004 modified: unison=4 voices, full Detune)
thanks!
sweetness...
 (preset004 modified: unison=4 voices, full Detune)thanks!
The King has spoken, therfore I am humbled.........
I am not worthy.
But Thanks.
						I am not worthy.
But Thanks.
