Pattern LFOs In Flexor III
THis has chapped my ass for a long time as I asked if there were charts of the various LFOs, and there aren't I suppose, so then I asked how to change these Patterns using a little more accuracy than the worthless drag and release method.
Again no reply, so I assume that someone here might know of a module or a way to externally change the Patterns through number selection or just an up/down method.
I am game for any suggestions as these LFOs are marvellous but selection is a workflow killer of highest order.
Ankyu.
next to nothing
Re: Pattern LFOs In Flexor III
Post by next to nothing »
I am probably misunderstanding you, but if you want to type in numbers in modular you could always do like this.
Of course you could use a bipolar constantval, but then you had to type -64 for lfo type 0 which is confusing :)
Also, for stepping thru with your left or right arrows, just click the waveform once, and step left or right. Ext.patt must be deactivated then ofcourse.
I was using the Constant and Ext. but not with the UniPolar conversion Module...........
Ankyu...
IT woks great but very slow, but accuracy is better than speed in this case.
Why the conversion module though....?
I am assuming it's for a looping/run status versus retriggering...?
next to nothing
Well the module apparently needs bipolar values to skip through wave 0-127. Using the bipolar constantval-module dierctly just messes my thinking up, since with the unipolar via conversion you can type 2 for wave 2, while with bipolar direct you need to write -62 for the same waveform. So it's just preference :)
I am not sure what you mean with slow though? Do you have a lag when u enter the value before the waveform is changed?
I see.....said the blind man.
Thanx again.
Modular Sundays are such a pleasure...
