CwMix16-16
roy thinnes
CwMix16-16
Post by roy thinnes »
16 stereo / 16 mono channel mixers (cwmix16-16, cwmix16-16c)
32 stereo channel mixer (cwmix32S)
on/off dsp switches for all channels -> minimal dsp usage
per channel:
preAmp
1 x pre-eq insert
4-way eq (accessible via channel number/edit button):
-low eq: lowCut2, lowcut4 or lowshelve
-lowMid eq: bp, lowshelve or paramEq
-highMid eq: bp, hiShelve or paramEq
-high eq: highCut2,4 or hiShelve
4 x aux
2 x inserts
pan
mute
solo
4 x bus
selectable channel colors + editable names
VUs:
-after preAmp
-after mixer channel fader
Download here
documentation
Cwmix24-8 download here
YISH313z
Re: CwMix16-16
Post by YISH313z »
:) Nice to see new devices still being made. I will use this on my next project, whenever I finish the current.
thanks
siriusbliss
Re: CwMix16-16
Post by siriusbliss »
looks AWESOME!
Can't wait to try it.
Thanks!
YISH313z
Re: CwMix16-16
Post by YISH313z »
:) I couldn't resist at least trying it... I like the eq on this mixer. Is it a creation of your own or stock?
ehasting
Re: CwMix16-16
Post by ehasting »
Looks great!! I will add it to the page later!!
Higen
http://www.higen.org
Mr Arkadin
Re: CwMix16-16
Post by Mr Arkadin »
I already added it to the list in that thread. :D
Nice job.
roy thinnes
Re: CwMix16-16
Hi and thanks for your comments.
Yish: its stock SC eq modules, which should be ok for most situations.
ehasting, your site indeed is really BIG. thanks for all your efforts!
Re: CwMix16-16
Post by jksuperstar »
Nice, I like how you can bypass "Master" for an ext signal...good for hooking up the Wave Device to :)
And your use of Send/Returns on the right side, instead of on the bottom like most devices, which makes the device in SCOPE too damn big with nothing but black box! Your way is much nicer for screen real estate. I also like the small design...mixers can get huge without adding more information visually. This will work for a none-touch screen perfectly ;)
Thanks!
Nike Pogoda
Re: CwMix16-16
Post by Nike Pogoda »
Nice...
One wish to add the information on loudness level on channels. What at once to see...
mausmuso
Re: CwMix16-16
Post by mausmuso »
Fantastic job.
I like to echo JK's real estate comment.
Couple of small poimts
I note the 'On top' button does not work exactly right.
Also I cannot seem to select Bus 1 on the channel or Aux outs.
Thanks for another great mixer!!
Re: CwMix16-16
Really nice mixer. Thanks a lot for that.
mausmuso
Re: CwMix16-16
Post by mausmuso »
Hi Roy,
I hate to be bearer of bad news but the mxer has no output on my Win 7 Pro 64 Bit SCOPE XITE x64 setup.
I can see the signals pre and post on the channels.
I can see the signal gets to the pre VU in the master section, but nothing on the output side.
Also I cannot get any output from Busses or Auxillaries either.
Has this been tested eslewhere on a 64bit setup?
I am pretty sure its not finger trouble, but I been wrong before.
Hopefully its me again...
regards,
mausmuso.
roy thinnes
Re: CwMix16-16
hi maus,
- yes, the onTop thingy won't work with Scope5.x, on 4.x it's ok. cannot do anything about that, sorry.
but about your other serious issues:
- in the Master section, have you switched to "ext Signal" by accident?
- have you noticed that the bus controls are pots (not switches)
- have you activated the busses / auxes?
I'm on 32bit pci and exerything (except onTop, s.a.) works perfect.
can't believe that this device doesn't work on your 64bit xite machine, but who knows.
any other xite user who cannot use it? would be too bad.
mausmuso
Re: CwMix16-16
Post by mausmuso »
Hey Roy,
I should have included more detail.
- No I was'nt accidently switched to ext signal
- I did notice they were pots not switches, however I may have not activated the busses/auxes - Doh!!
I will check next time I'm in the chair.
Thanks a lot
Regards
maus
Mr Arkadin
Re: CwMix16-16
Works fine here on 32-bit XITE-1.
t_tangent
Re: CwMix16-16
Post by t_tangent »
Thanks Roy, another superb device, and much appreciated. Look forward to trying this out. :)
mausmuso
Re: CwMix16-16
Post by mausmuso »
Hi Roy,
Busses and Auxiliary outs all working - sorry I forgot to activate them.
The Master out I am afraid still does not work for me.
Has other x64 users noted anything?
I can now use the mixer with a small work around (Use a Bus as the out)
Thanks at lot.
next to nothing
Re: CwMix16-16
Post by next to nothing »
I'm on win7/64 as well, and i just used the mixer for a limited time, mostly just using my system as a wave soundcard for non-music related stuff. Can't say i have had any problems with the master out. I did forget to activate buses as well when i tried it briefly with a synth though :)
next to nothing
Re: CwMix16-16
I am on PCI cards though.
roy thinnes
Re: CwMix16-16
sorry, a little bugfix (master inserts fx1&2 had linked onOff buttons).
please download it again.
thanks Thomas!
