Hey again.
Is there Anyone who knows a Wave recording prog!! so i can Record waves
outside my sequencer! CB6.
Anything that support the asio for SC
Cant even use the STS on 64b Tssss.
i have to use Kontakt or Battry or Halion. or Akai S whatever....5.4.3.2.1000
i Like my STS Fuckman.
BTW i got a -I7 Qcore-Win7-16G Ram-Asus MB-PCI SC-
All the whrit thing to make the Rig as competeble as posible for SCore!!!!!
I hope for A proffesor in Musicland who fix these Probszzzzzzzz!
GrTz all
Jerome.
2 WaveLab 7 Or..? i what to recored outside my SeQ!!!! damm
Audio-Active
Re: 2 WaveLab 7 Or..? i what to recored outside my SeQ!!!! d
what about V-DAT, it sounds very good.
Audio-Active
Yes!
Cant find it in my plugs and if got a NFR so i must ta a better look!
i thought abouth that didnt rty yet,
but thanx for th reply.
GrtZ Jerome
GrtZ Jerome
what are you trying to record are trying to sample for sts
sample robot is the best program for doing samples of your synths to use them as sampler instruments
and it saves in sf2 which sts can read it also does multi layer velocity sensitive instruments you can do 8 layers for kontakt or just do 4 like akai and save to sf2 and load them in that way
vdat sounds great and is good for doing multitracking
i use nuendo and do all my mixing in the scope as the mixer is way better and then record the tracks into vdat
Audio-Active
Hey Neutron.
I found the Vdat & the VCR128.. it works!
Why do i want to rec outside my CBase, is the following thing:
If i want to make a Wave file from several different vst plugs and and edit them in the recording,
I have to change channels in the sequencer CBase and thats not possible!
I am able to edit them before I record but thats not what i am looking for.
So thanks a lot for your tips!
(btw are you THE Neutron who makes those nice synths for CW??, cool stuff !!)
Are you still working with VDAT yourself?
From now on I will start working with VDAT and I might have some more questions in the future.
Any more tips about combining VDAT & VCR128, or is it possible to just use VDAT by itself.
Greetings,
Jerome
Greetings,
Jerome
you can also route back into a new Stereo track in Cubase....
