Lost audio in and out
jim901s
Post by jim901s »
Recently my system had a crash within Samplitude.Now i can't record into it or play any of the files that were already recorded from other sessions.My scope seems to be ok.I am running a simple set up,Two pulsar 2 cards.My routing is pulsar 2 Adat source to asio 24 bit dest .I also have a wave source and a asio source through a 4 channel mixer for play back.The weird thing is i can play my drum sample wave library fine.I have reinstalled Samplitude and checked all the hard connections.My pc was built with Recommendations from Gary B and does not have Internet.Should i try a scope reinstall?
Any help would be great.
I am on the verge of selling off the hole system if i can't get it working.
James
mausmuso
Re: Lost audio in and out
Post by mausmuso »
Hey James,
I too have just had issues with SAM Pro X and SCOPE 51. 64bit XITE-1.
My issues were different to yours.
It started when I swapped out the SCOPE ASIO in for another ASIO source and then I could not swap back!
I found I had the same issue with Reason, but Cubase 6 and Kontakt 5 worked fine (swapping in and out, etc)
Anyway in the end I disabled the SCOPE drivers and rebooted and let them load again and it sorted itself out.
I suggest you try that before blaming SAM.
Good luck.
Maus
post a screenshot of the sam audio settings and your Scope project.
you're not using ASIO with samplitude?
jim901s
Post by jim901s »
Not sure how to post the screen shot.But my Samp audio is as follows
Asio is checked
device is Asio Scope
clock is cw dsp hardware
buffer 1024/32 bit
out 1089 + in 1089
vip object 4096
32 bit
tape monitor
mix input checked
My routing window is
pulsar 2 adat A and B source to asio 24 dest,total 16 tracks
also have a wave source stereo and asio source stereo to a den mixer and then to wave dest and pulsar 2 analog dest.
siriusbliss
Post by siriusbliss »
If something crashes Samplitude, then it SHOULD all come back to normal after a reboot of your PC and resetting the ASIO drivers in Samplitude.
Otherwise it's also often possible to shut down Scope and just reboot Scope and they should come back.
I've reported to Magix Samplitude development beta team that I'm seeing a difference in ASIO 'locking' stability in Samplitude 64-bit Win7 environment from the old 32-bit setup, where I never had problems switching ASIO channels or just resetting them.
mausmuso
Post by mausmuso »
Hi Greg,
I agree with all you said.
That has been my experience as well.
However recently I installed Magix Video Edit Pro MX and since then I had trouble when I swapped out the ASIO in SAM and then tried to put it back (which does not make a lot of sense I know as it does not have an ASIO driver, so it was probably unrelated).
Thats when I had to reinstall the SCOPE dirvers to get things to work properly again.
SAM has always been very forgiving prior to this as you stated.
Hopefully it is again.
Time will tell.
maus
jim901s
Post by jim901s »
Well so far i have had no luck.I don't think it is a scope related problem.I can play cd's in the computer fine.The signal shows up in the dynamic mixer ok.Within Samp i can play my wave file drum samples ok also.It just won't play any of the recorded projects.I did another full uninstall and install of Samp.It made no change.I tried a Scope reinstall but I can't find my code to let the program run.Now what?Help.
I am guitar player first and a computer guy last so this is very frustrating for me.
James
you must have had a keyfile when you first installed Scope. where did it go?
does Scope run right now? if it does, then you HAVE the keyfile. copy scope.rgy from Scope\app\bin.
what version are you trying to install? if you have the keyfile, put it in a zipped folder and pm me with it.
t_tangent
Post by t_tangent »
jim901s wrote:Not sure how to post the screen shot.
Select the window you want to capture the screenshot of and then hold down 'ALT' and press 'Prnt Scrn'. (To state the obvious, 'Prnt Scrn' means Print Screen)
Then open up the Windows program Paint (in Windows XP you can find that from 'Start -> Programs -> Accessories -> Paint' or in Windows 7 it is at 'Start -> Accessories -> Paint') and then press 'Edit -> Paste (shortcut is Ctrl + V). This will paste the captured screen into Paint that you can then resize and save as a file for posting here.
If you want to capture the whole of your screen rather than just one particular window then you only need to press 'Prnt Scrn' then paste into Paint.
Hope that is useful
jim901s
Post by jim901s »
Yep that helps,Had a long chat with Gary B and all is well.I even got Samplitude working again.Its not done yet but here is my routing window so far.Well i thought i could post the screen shot,i have it on a flash drive but the forum says the extension bmp is not allowed. :-?
James
next to nothing
Post by next to nothing »
Save it as .jpg (JPEG).
jim901s
Post by jim901s »
Looks like it worked this time
here ya go
here ya go
