HELP! XITE communication error
hello,
FYI: I am posting for a bandmate ...
New PC -> ASUS P8P67 Rev. 3, i7, 16 gb ram, 3 hd's, graphics card gigabyte hd6700
Old Scope 15dsp card did work -> pci bandwidth limit reached ... nothing helped ...
see also this thread http://forums.planetz.com/viewtopic.php?f=19&t=30557
ordered XITE 1D ... installaion/aktivation went well ... when scope 5.1 is being started an error message occurs ... click ok -> then I can use xite ...
when inserting some new hw-modules (adat source for a16 ...) a lot of error messages are displayed .. see pics ... really annoying!
any hints? seems to be a irq issue ... new mobo? I don't wanna get a new processor too ... would like to use all components I've bought so far ...
greetz
tom
greetz
tom
- error.JPG (13.07 KiB) Viewed 7405 times
- error2.JPG (16.33 KiB) Viewed 7405 times
- xite-fehler.JPG (21.03 KiB) Viewed 7405 times
Re: HELP! XITE communication error
Have you removed the old PCI 32bit card.....?
Scroll to the bottom of the 'XITE-1 Installation & Tips' section here, where GaryB gives a fix hint for this error :
http://www.hitfoundry.com/issue_09/xit_mast.htm
Worked for me. And I didnt have to uninstall the PCI boards (still using 'em).
yes, removed the old pci-card ...
will try garyb workaround right now ...
thanx so much for trying to help
cheers
tom
cheers
tom
OK, changed cset.ini ...
no error at startup ... but after a few seconds .... error copy protection violation ... and then error communication failed ...
cset.ini
[hw]
intBlkSize=256
SelectDriver=2
board0=scope-xite3
[scope-xite3]
xiteRev=3
[SC Scope]
xite=1
Build=v5.1.2709-x64
[Runpep]
InScreen=0
Language=deutsch
[FileBrowser]
All Files=0
STS-Samples=0
LastPath=C:/Program Files/SCOPE XITE/Devices
[AudioFormats]
Wav=Wav
[Installer]
Version=5.0
App=SCOPE XITE-1
OS=5.0.2201
ProductID=1
[ReferenceResolver]
All files_Paths=C:\Program Files\SCOPE XITE/;
Modules/Devices_Paths=C:\Program Files\SCOPE XITE/Devices/;
Presets_Paths=C:\Program Files\SCOPE XITE/Presets/;
All files_AutoUse=1
Modules/Devices_AutoUse=1
Presets_AutoUse=1
[StaticPath]
Modules=
Modular=C:\Program Files\SCOPE XITE/Modular Modules/
Projects=C:\Program Files\SCOPE XITE/Projects/Examples/
Effects=C:\Program Files\SCOPE XITE/Devices/Effects/
Presets=C:\Program Files\SCOPE XITE/Presets/
HardwareIOs=C:\Program Files\SCOPE XITE/App/Application/IOs/Hardware/
SoftwareIOs=C:\Program Files\SCOPE XITE/App/Application/IOs/Software/
Bitmaps=C:\Program Files\SCOPE XITE/MRC Skins/
Devices=C:\Program Files\SCOPE XITE/Devices/
Samples=C:\Program Files\SCOPE XITE/Samples/
[Path]
Projects=C:\Program Files\SCOPE XITE\Projects\Examples
[APPEARANCE]
ToolTips=1
DragWindows=1
StandardCursor=1
GridY=6
GridX=6
[LOAD]
AlignSurfaces=1
LoadMixer=STM 1632 X.dev
LoadMixerEnabled=1
LoadDefBoard=0
[AUTOCONNECT]
InstrumentToMixer=1
EffectToMixer=1
AudioSrcToMixer=1
DeviceToMidiSrc=2
[SEQPATH]
Path1=
[ASIO]
XTCMode=0
application=C:\Program Files\SCOPE XITE/App/XTCApp/XTC.pro
Pluginwrapper1=C:\Program Files\SCOPE XITE/App/XTCApp/vstsynthplugin.mdl
Pluginwrapper2=C:\Program Files\SCOPE XITE/App/XTCApp/vstplugin.mdl
Pluginwrapper3=C:\Program Files\SCOPE XITE/App/XTCApp/vstplugin.mdl
Pluginwrapper4=C:\Program Files\SCOPE XITE/App/XTCApp/vsthostplugin.mdl
[XTC-Config]
AddHost=1
SelectDriver=2
intBlkSize=256
[Host]
Scoperev=128
[Host-Config]
Numboards=1
Board0=Host
[SFP]
Favourites_Minimized=0
Favourites_Size=102
FileBrowser_Minimized=0
FileBrowser_Size=435
ReferenceResolverOptions_SizeY=300
ReferenceResolverOptions_SizeX=332
ReferenceResolverOptions_PosY=106
ReferenceResolverOptions_PosX=315
ReferenceResolverOptions_Show=0
Dsp Load_SizeY=106
Dsp Load_SizeX=194
Top_Minimized=0
Top_Size=420
About_Show=0
About_PosX=254
About_PosY=14
ControlRanger_Show=0
ControlRanger_PosX=289
ControlRanger_PosY=89
ControlRanger_TopLevel=2000
SFPBar_PosX=4
SFPBar_PosY=4
SFPBar_SizeX=238
SFPBar_SizeY=519
SFPBar_TopLevel=100000
SFPBar_RestoredSizeY=582
Bottom_Size=88
Bottom_Minimized=0
DSPLoad_Load=0
Dsp Load_Show=0
Dsp Load_PosX=282
Dsp Load_PosY=82
Dsp Load_TopLevel=2000
Registry_Load=0
ModuleRegistry_Show=0
ModuleRegistry_PosX=300
ModuleRegistry_PosY=102
ModuleRegistry_TopLevel=2000
Options_Load=0
Options_Show=0
Options_PosX=296
Options_PosY=96
Options_TopLevel=2000
Resolver_Load=0
ReferenceResolveOptions_Show=0
ReferenceResolveOptions_PosX=302
ReferenceResolveOptions_PosY=104
ReferenceResolveOptions_SizeX=332
ReferenceResolveOptions_SizeY=250
SFPRouting_Show=1
SFPRouting_PosX=831
SFPRouting_PosY=12
SFPRouting_SizeX=1047
SFPRouting_SizeY=880
SFPRouting_TopLevel=0
FileBrowser_Show=1
FileBrowser_PosX=253
FileBrowser_PosY=5
FileBrowser_SizeX=241
FileBrowser_SizeY=518
FileBrowser_TopLevel=1
Splitter_Size=0
Splitter_Minimized=1
SFPDesktop_PosX=1932
SFPDesktop_PosY=3
SFPDesktop_SizeX=1902
SFPDesktop_SizeY=1076
SFPDesktop_Maximize=0
PulsarConfigSurface_Show=0
PulsarConfigSurface_PosX=274
PulsarConfigSurface_PosY=75
PulsarConfigSurface_TopLevel=2000
[Scope]
PulsarConfigSurfaceShow=0
PulsarConfigSurfaceY=485
PulsarConfigSurfaceX=535
[RecentFileList]
Entry5=
Entry4=
Entry3=
Entry2=
Entry1=
Entry0=C:/Program Files/SCOPE XITE/Projects/Examples/xite_micha.pro
will wait if someone could give another advice in the next days ... if not my bandmate will return xite ...
and that's probably the end of the scope route
greetz
tom
cset.ini
[hw]
intBlkSize=256
SelectDriver=2
board0=scope-xite3
[scope-xite3]
xiteRev=3
[SC Scope]
xite=1
Build=v5.1.2709-x64
[Runpep]
InScreen=0
Language=deutsch
[FileBrowser]
All Files=0
STS-Samples=0
[AudioFormats]
Wav=Wav
[Installer]
Version=5.0
App=SCOPE XITE-1
OS=5.0.2201
ProductID=1
[ReferenceResolver]
All files_AutoUse=1
Presets_AutoUse=1
[StaticPath]
Modules=
[Path]
[APPEARANCE]
ToolTips=1
DragWindows=1
StandardCursor=1
GridY=6
GridX=6
[LOAD]
AlignSurfaces=1
LoadMixerEnabled=1
LoadDefBoard=0
[AUTOCONNECT]
InstrumentToMixer=1
EffectToMixer=1
AudioSrcToMixer=1
DeviceToMidiSrc=2
[SEQPATH]
Path1=
[ASIO]
XTCMode=0
[XTC-Config]
AddHost=1
SelectDriver=2
intBlkSize=256
[Host]
Scoperev=128
[Host-Config]
Numboards=1
Board0=Host
[SFP]
Favourites_Size=102
Dsp Load_SizeY=106
Dsp Load_SizeX=194
Top_Minimized=0
Top_Size=420
About_Show=0
About_PosX=254
About_PosY=14
SFPBar_PosX=4
SFPBar_PosY=4
SFPBar_SizeX=238
SFPBar_SizeY=519
Bottom_Size=88
Bottom_Minimized=0
DSPLoad_Load=0
Dsp Load_Show=0
Dsp Load_PosX=282
Dsp Load_PosY=82
Registry_Load=0
Options_Load=0
Options_Show=0
Options_PosX=296
Options_PosY=96
Resolver_Load=0
SFPRouting_Show=1
SFPRouting_PosX=831
SFPRouting_PosY=12
FileBrowser_Show=1
FileBrowser_PosY=5
Splitter_Size=0
SFPDesktop_PosY=3
[Scope]
[RecentFileList]
Entry5=
Entry4=
Entry3=
Entry2=
Entry1=
greetz
tom
The copy violation thing seems to be an issue with the connection between the card and the rack module.Is the cable ok? Inserted the whole way? Bend? I d try to unplug replug while everything is off.Also check the power supply.Plug it into a different outlet as groundloops-problems seem to trigger that error easily.
And turn on the XITE before you turn on the PC
tried everything ... no chance ... xite turned on before pc is turned on ...
changed hdmi cable ... no way
will wait til saturday ... maybe try one last time
thanx to all of you
cheers
tom
thanx to all of you
cheers
tom
Its a weird error.There must be something up with the pc as its working for most people.Where are you located if you dont mind asking? I gladly help in person as these things can be very fricky to sort over the web.And ...did you get a new product? This is very important!
Just a simple thing: You installed the new XITE version of SCOPE, and you are running that? And you are NOT running the PCI version of SCOPE? Make sure any links you use to run SCOPE are pointing to C:/Program Files/SCOPE XITE or similar.
I only ask because the initial error mentions PCI master issues. The XITE-1/D has different hardware I/O, and uses different devices within SCOPE to access them, which would explain the second error you listed. It would also explain Serial Number/Copy Protection issues noted.
Good thought! All reg entries in windows should be deleted from the old install.jksuperstar wrote:Just a simple thing: You installed the new XITE version of SCOPE, and you are running that? And you are NOT running the PCI version of SCOPE? Make sure any links you use to run SCOPE are pointing to C:/Program Files/SCOPE XITE or similar.
Next step would be to try it on another PC for sure. If it works, problem solved. If it doesnt, then most likely XITE unit needs to be sent back to base.
Hi all,
some more info:
updated to 5.1 version of scope for the old 15 dsp-card after for the new pc ... as I mentioned eralier ... scope card and 5.1 software didn't work (pci bandwidth problems).
so we decided to get an xite-1d and return the old scope card to sonic-core.
after receiving xite 1d we pulled out the old card and inserted the express card.
prior to installing the scope version for xite -1d we made a backup copy of the original scope folder then did an uninstall of the scope software.
after that we did an install of new scope 1d version (dvd that comes with xite -1d). everything went fine ... copied the 2 files manually as recommended in the installing instructions. then we imported the keyfile ... OK.
so far so good. but then this weird error occured when starting the scope software (communication error).
fixed that with manipulation of cset.ini like garyb recommended.
disabled nearly "everything" in bios and os (win7 64 bit). no energy saving at all ...
we also had an error called 30 hardware detected ... could not connect to scope hardware ... but that dissapeared aftre rebooting ...
it's not my hardware so I have to drive to my friend location to check if we can get things sorted out.
I think it is a mobo/graphics card issue ... checking the registry for old scope entries is a good recommendation. mabe I should uninstall the whole thing do a fresh install of scope xite-1d softwware. before that deleting all scope related entries maybe this works ... is there anyone out there using a ASUS P8P67 Rev.3 with xite ... just curious ....
will keep you informed ...
thanx again for the advices.
greetz
tom
btw.: I am located in Stuttgart, Germany.
some more info:
greetz
tom
that sounds like either a bad hdmi cable, or power saving settings in windows that need to be disabled. is the XITE sharing an irq with anything?
hi garyb,
- used 2 hdmi cables (the one from that comes with xite and antother one) ... didn't help ... will use another one this evening ...
- I have already disabled all power saving settings in windows and imo the error message would not pop up that fast - only if something goes to "sleep"
- irq is 18 but I didn't check out if this irp is shared. isn't it true that if so there's no chance to have xite it's "own" dedicated irq. but I'll check that this evening ... if the irq is shared then I try to disable the corresponding device ... hopefully nothing important ..
btw: in that mobo are 2 pci-express slots available I could use. unfortunately one is totally covered by the graphics card (sitting under it) so the only possibility is to use that one cnext to the graphics card.
tom
tom
- Mr Arkadin
Did you download and install the latest version?dtb wrote:after that we did an install of new scope 1d version (dvd that comes with xite -1d). everything went fine ...
The latest versions can be found here:
ftp://sonic-core.net/software/scope_5.1 ... x64_EN.exe
OK, will try that ... seems to me as if it'll be a busy evening ...
Glad you all try to help us . my bandmate is distraught ...
best
tom
- Mr Arkadin
Just to double-check - that's the 64-bit version I posted. I think you said in another thread you were 64-bit, is that right?
yep, 64 bit ...
os is win7 64bit german - is it recommended to use the 64bit en version?
as far as I rember when installling scope yesterday I had the option to choose the language (choose german)
tom
tom
- Mr Arkadin
When I select the German version by viewing the site in German it seems to be the same - so I assume it's just one installer.
Here's the page:
http://sonic-core.net/joomla.soniccore/ ... 54&lang=de
Here's the page:
