Vectron waveforms
Preset lists and tools for Scope modules
next to nothing
Vectron waveforms
Post by next to nothing »
This is a vectron presetfile consisting of of the following waveforms :
Revision 2 (initial release)
- 128 waveforms of fairlight vox samples
- 128 waveforms of a transwave
- 128 waveforms of a ppg upper wavetable transwave
- 64 waveforms of a wavetable math formula4
Added in Rev.3:
- 69 waveforms from a Virus synth
Added in Rev.4:
-64 waveforms PPG WT01 Resonant 1
-64 waveforms PPG WT02 Resonant 2
-64 waveforms PPG WT03 Maletsynth
-64 waveforms PPG WT04 Square Sweep
-64 waveforms PPG WT05 Bellish
All samples done by the user "jhulk", compiled to preset by myself.
Preset is to be loaded in Vectrons "wavecreate" screen. Once the preset is loaded they will show up in the waveform select dropdown menus in the main window.
Regular presets can be made using individual samples from the different banks.
In general, only the latest revision is needed as the waveforms from the earlier revisions are included. Last revision will be kept here for backup purposes in case the new revisions screw something up for user patches (allthough they really shouldn't...).
Enjoy.
VectronWaves_rev4.rar
See description further up.
(295.86 KiB) Downloaded 1165 times
VectronWaves_rev3.rar
Now 69 waveforms from the Virus is included. IMPORTANT: There is NO point in downloading this file unless you are having problems with patches you made with rev.3. Yes the virus part is also in rev 4. plusplusplus.
(206.75 KiB) Downloaded 956 times
Last edited by next to nothing on Wed Feb 15, 2012 1:39 pm, edited 6 times in total.
Mr Arkadin
Re: Vectron waveforms
Post by Mr Arkadin »
The effort and generosity of the Scope community shows itself again, proving it's more than just about software or hardware.
Thank you kindly.
next to nothing
I should rather thank YOU for your contributions :)
jhulk
Post by jhulk »
your fizmo wavetable sound creations please mr arkadin
in fact any transient or fm or any patch you like the sound of in f3 for 1 to 2 seconds
thats anybody can contribute to this and i will make a transwave from it and a 128 user wavetable with single cycles
being named after the person who sent the sample
it can be spoken word
Mr Arkadin
jhulk wrote:your fizmo wavetable sound creations please mr arkadin
It'll be a couple of weeks as it's having its regulator fixed at the moment. Also I'm quite new to it so I need to figure out how to just get a clean transwave recorded minus all the layers and effects.
jhulk
Post by jhulk »
if you need any help give me a shout i can put you in the right direction
but any samples will do i have all the fizmo wavetables any way as i have one what i was saying was have a layered patch
with 2 layers and filter modulation but no fx just transwave modulation either by envelope or lfo
but any remarkable synth patch you like
that goes for any body
the more the merrier
Ben Walker
Post by Ben Walker »
Wow, thanks for these - great to dust off the old Vectron for these. It's such a cool synth and these are geat waveforms!
jhulk
Post by jhulk »
hay ben i done the d50 partial set
liked your jaded modular im working on the d50 equivelent
you up for the best patches of vectron then with the new waves
Post by jksuperstar »
jhulk...until the transwave oscs are done for SCOPE ( :D ), can I get a copy of your fizmo wavetables? I am repairing an asr10 rack and would like something to play with :)
jhulk
Post by jhulk »
im an repair tech as my day job i used to work for an ensoniq authorized repair work shop and was the one who went to the states
for learning how to fix problems
if you need any help let me know
now for the transwaves yes ican let you have someof the fizmo ones
ill search for them but if i give you just th transwaves will you be able to program them or do you need me to show you how
as many get stumped
or are you after actual eps/asr instruments with the actual transwave already configured into a patch
also to make the fizmo sound you need to layer them in dual voices
but the asr10 is way much more capable than the fizmo as you can layer 8 totally different transwaves at the same time
and with still 4 note poly it blows the fizmo away
and the fizmo transwaves are not that good most came from the vfx
where as the asr10 you can make and use what ever table you want want ppg you got it want uwave you got it blofeld
no problem the esq1 spectra there you go m1 t1 virus d50 jd800 jd990
and you can morph fron one sound to another
you xan say chose a shruthi diy synth wavefrom on slot 1 a jd800 fatsaw on slot 2 or any wave on a slot over 128 slots then interpolate spectra as all slots are changed into additive spectra sin/cosin the sin is in phase the cosin is reverse phase thats why a waveform on the k5000 looks diferent from the waveform that you put in as its only sin additive so there is no reverse phase from cosin
and becuase it is done in spectra they always start at zero crosing and end in zero crossing so no clicks
but any help you need no problem
These are just another powerful group to add, thanks so much.
THey are so strong, I run the Grunge knob at 50%, Volume at 3'0'clock..
Thanks NTN, JHulk.... :wink:
next to nothing
New revision added with 5 banks of PPG waveforms.
next to nothing
i have no idea why why more people are downloading rev.3 rather than rev 4.
Just to make it clear, all (and more) waveforms are included in the later revisions.
New Fairlight CMI 30A
next to nothing wrote:This is a vectron presetfile consisting of of the following waveforms :
Speaking of Fairlight, theres a new ( well, 2009 is relatively new for an 80's synth) one :
http://www.synthtopia.com/content/2009/ ... o-cost-5k/
neuromantik
Post by neuromantik »
Just discovered this thread, Thanks!! Lots of love and work went into this :)
Not wanting to be a thread hijacker or simply a waveform junky, but would anyone happen to have the TG33 waveforms handy since I'm really looking for that cold dronish character, I'm actually working on a TG33 modIV patch (2op FM part is easy... :P)
jhulk
Post by jhulk »
i have done the modular dev with flexor3 modules for the
vector mixer switching from volume to pitch
and do have the sample waveforms
will be releasing it once i have the web site up and running
Bump for vectron fizmo wavetables and any other transwave bliss!
jhulk
Post by jhulk »
wait and see all will be revealed soon
faxinadu
Post by faxinadu »
brilliant, thanks!
http://www.oceanswift.net
Music
Yogimeister
Post by Yogimeister »
Big Thanks ! :)
(and +1 on the TG33 ;)
