Obviously the old STW vintage EQ, 4080 and compressor don't work in 64 bit environment. But do they work in the w7 32 bit OS? I love the old EQs, but may be newer modules are just as good.
Only asking because my new system is 64 bit only at the moment.
STW question
- Ricardo
- garyb
- Moderator
Re: STW question
yeah, they should work in 32bit.
plugins that require system resources like memory need to have sys files rewritten for 64bit.
- Ricardo
Music Manic
Re: STW question
Mine are working in 64bit windows 7.
- garyb
- Moderator
Re: STW question
there you go.
- Ricardo
Re: STW question
Really!! I couldn't get mine to load. May be I put the wrong files in the wrong folders, but I was really careful. I also tried to install from autorun with no luck.Music Manic wrote:Mine are working in 64bit windows 7.
Which version did you load?
Any tips or help would be great if possible...
R
Re: STW question
They are working fine here too ! Without any tips. Do you have the latest update ?
- Ricardo
Re: STW question
Not sure. The latest I have is timeworks III 3.2. Are/were there any more recent? I've been out of the scene for quite a few years.
R
Music Manic
Re: STW question
Ricardo wrote:Really!! I couldn't get mine to load. May be I put the wrong files in the wrong folders, but I was really careful. I also tried to install from autorun with no luck.Music Manic wrote:Mine are working in 64bit windows 7.
ftp://sonic-core.net/software/scope5/pl ... Timeworks/
