DAS C350 Update
Planet Z Announcements
DAS C350 Update
DAS have released an update of the C350 Channel Strip. Its called the C350L and is a free update for all C350 owners :
http://www.digitalaudiosoft.com/index.html
Optimised using the latest SDK from S|C it allows more instances to be loaded on XITE-1 hardware, as well as adjustments to the GUI and knob calibration :
DAS C350L
DAS C350L
siriusbliss
Re: DAS C350 Update
Post by siriusbliss »
Awe-some!
Thanks!
G
Re: DAS C350 Update
Another perfect companion for Solaris.
I was going to use the DAS Gate and Brickwall Limiter since Solaris has it's own EQ, but it's 3 Band and I always liked the CHannel Strip approach when only using a few instruments form outside the Box.
The Compressor with high ratios acts as a Brickwall Limiter. I tested the below settings with Solaris. Solaris' Volume knob was at 50%, when I cranked it I heard no difference in the levels, so now I have what I need for the SE-1 and Solaris. These are very powerful beasts and each preset can easily have jumps in the level that make performing less enjoyable as you must concentrate on whos playing what and using your ears instead of ignoring the players and having to reset your levels...........most irratating.
Also Solaris has a damping feature for it's georgeous 96k Delay, and instead of using the Keyed DAS Gate, which is overkill, the C350L Gate is the same quality with less features, but clips the effects tails perfectly.
Damn between DAS and RoyT. I have had a beautiful Solaris week.
Now let's see if the C350L can tame the powerful SE-1, the punisher of anything Native, and virtual.
That's a test, as the C350 didn;t take away any transients from the Solaris, so if the same tricks work on the SE-1 I will be a happy camper.
Thanks Dante, and thanks Olive, Eric and Thomas.......my brotha's from other muthas'........
babaorum
Re: DAS C350 Update
Post by babaorum »
Do you talk about Solaris software or hardware ?
Sonic Core Luna II + Pulsar II scope v5.1.2709-x64, Cubase 9.0.20 (64), Pro Tools 12.7, Wavelab element 9 (64), windows 8.1 pro (64), Asus P6T 18Go RAM core i7 920, SSL Duende Native - Lexicon PCM Reverb Bundle - Waves - Sonnox
Re: DAS C350 Update
Hardware version.
Using Analog I/O so far but have the Hosa ODL-312 AES/EBU Converter, and new MOTU USB to MIDI 8 x 8 coming, so the signals might be an improvement at 96k, we shall see.
But again the C350L is really nice update.
Brickwall quality at using the Compressor at high ratios, and the same quality of the DAS Gate, but lacking many features meeded for super tricky sidechaining stuff.
fidox
Re: DAS C350 Update
Post by fidox »
Thanks for this update link :)
Liquid EDGE
Re: DAS C350 Update
Post by Liquid EDGE »
Will one need a new activation key for this or will the one provided for the dasc350 work?
(just got the dasc350 today and await keys for it so wonder)
fidox
Re: DAS C350 Update
Post by fidox »
Mine works normally without new key file ;)
ehasting
Re: DAS C350 Update
Post by ehasting »
I just had to order myself! dang what a great offer! i am so happy today!
Higen
http://www.higen.org
YISH313z
Re: DAS C350 Update
Post by YISH313z »
This will not load for me despite having the regular C350 :(
Re: DAS C350 Update
Have you written to DAS support support@digitalaudiosoft.com ?
or maybe you need the updated files if your running 64 bit :
http://www.digitalaudiosoft.com/plugins ... igned-SYS/
http://www.digitalaudiosoft.com/plugins ... EQ-Bundle/
DASCOEFF11.sys is for Legend + C350 +Masterit EQ
Also you need Scope 5.x
