Latency
Discuss Scope XTC mode.
fraz
Latency
Post by fraz »
Latency for input/output in Cubase is around 24ms - However, in the ASIO control panel for Scope XTC I've altered the latency to 7ms a bit like you do with Scope in normal mode. When I play a Scope/Pulsar synth the delay doesn't seem like 24ms (it may be tho as I may be wrong) - Is it possible that the Scope is at 7ms as set in the XTC version of the ULLI???? and not the 24ms that Cubase states?
the19thbear
Re: Latency
Post by the19thbear »
Xtc mode has bugs. This in one of them.
You have to manually edit a file called cset.ini and write the latency you want, 64 ,128,256 etc.
Search for cset.ini and latency here on planetz and you will find all the info you need:)
