WINDOWS 7 Cubase 6 set up
korgano
Post by korgano »
Hi everybody,
just a tought:
We are living in 21st century and it is not possible to install Windows 7 ( original ) and Cubase 6( original ) and SCOPE 5.0 ( original ) and record without plops and glitches.
I had same Cubase 6( original ) and SCOPE 5.0 ( original ) installed on same PC with WIndows XP and it worked fine. Of course after planty tweakings.
I just wish that soon it will be possible to install OS and Software and get going without tweaking on windows, bios and who know what else :-)
Cheers !
Re: WINDOWS 7 Cubase 6 set up
all of those work fine together, EXCEPT-
if you have irq sharing with a pci card, you will have trouble.
if you have cpu power stepping enabled, you will have trouble.
if you have a socket 1155 processor and a pci card, you will have trouble.
korgano
Post by korgano »
Thanks GaryB..arlow??? :-)
No..none of that.
cpu power stepping enabled...dont know what is that, but I guess something with overclocking or so.
Anyway my PC is working fine with XP and same software.
So I guess IRQ is not issue.
Now with WIN 7 i have this glitches and pops etc as described below.
I just dont understand why we have to go through this everytime we install any Windows OS?
It would be good that Sonic Core gives set up for Windows 7 so people can work fine with their equipment as it should be.
CPU Power Stepping is a BIOS setting, so the tweaks GaryB mentioned need to be done in BIOS (if you havent already) .
S|C do recommend the BIOS tweaks :
http://sonic-core.net/joomla.soniccore/ ... 56&lang=us
Although I dont think it mentions powerstepping, this is different from overclocking. bottom line is it needs to be turned off in BIOS.
korgano
Post by korgano »
Thanks, but I dont have any of Core i7, i5, i3.
I have Intel® Core™2 Quad Processor Q6600.
Why should I tweak BIOS when is working fine with XP?
korgano
Post by korgano »
tomorrow I will try with MOTU 8pre.
I will let you know.
Thanks for all help!!!
korgano wrote:Thanks, but I dont have any of Core i7, i5, i3.
BECAUSE YOU'RE NOT USING XP!!!!!!!!!!!
