Opt. S/PDIF in Pulsar I board ?
Peter Cherry
Post by Peter Cherry »
I have Pulsar I card and now (in v3.0) I noticed that there is optical S/PDIF option instead of ADAT in Samplerate settings.
Is it possible to run this on my old Pulsar I ? I tried to connect Sony minidisc optical out to Pulsar ADAT in, but no signal came through.
And also, now I must use old coax dest module, becouse module from version 30 doesn´t work.
Peter
subhuman
Post by subhuman »
Peter Cherry
It´s some kind of bad joke, I downloaded new Creamware Patch, but the situation is the same.
Peter
Peter Cherry
But mÿ question was on another problem:
Have you some experiences with that ?
Peter
subhuman
Post by subhuman »
You know you've installed it correctly, when the UnZip program prompts you "Overwrite files?"
Otherwise you didn't put it in the right directory... the README file inside the archive/patch may prove useful here.
and sp/dif optical is "extra".i just manually installed the files in their proper directories (the files NOT the folders)after unzipping to a cdrw.it worked great.
Peter Cherry
What do you mean with ,,extra´´ ?
Does your Pulsar I work with ADATs as Optical S/PDIFs ?
dbmac
Post by dbmac »
Mine doesn't
oeps here i had to censor myself. i was typing some stupidities 3-)
<font size=-1>[ This Message was edited by: atomic on 2001-10-22 00:41 ]</font>
o.k. gotta admit,i don't know what i mean by extra and i will try optical sp/dif. coax sp/dif works fine.............
