Control Room with 5.1 Setup...
A space for learning and studying the Scope environment and music-making in general.
thehe
Post by thehe »
Hey guys,
currently I have a 5.1 Tannoy setup in my Control Room but (because of space problems) my primary three screens are located between center and right monitor...
I have a z-link box (8 channels) connected to the dolby setup:
1 - L
2 - C
3 - R
4 - SBL
5 - SBR
6 - Sub
7 - LS
8 - LR
What I currently did was just connecting the main mix stereo out to:
L -> C (2)
R -> R (3)
L -> SBL (4)
R -> SBR (5)
L -> High-Cut -> Sub (6) for a little bit of PUNCH...
but I think it's not a good idea to pull the Subwoofer-Signal out of just one Channel of the stereo-mix...
There's not enough boom, the Tannoys are currently NOTHING below ~80Hz and I don't want them to connect to the subwoofer X-over for some reasons.
Now I used the STM 16S for the mix - but this creates the typical dolby-experience and does not represent the original mix and eats a lot of DSPP...
The sub sounds great (with XOver set to 82Hz)...
If I use just a MicroMixer in Mono-Mode and mix L+R a little bit, the sub sounds strange again...
Any constructive ideas? (i know that's not IDEAL!)
Greetings,
Robin
heat 'em up!
heat 'em up!
