has anyone used it effectivelly in any musical gear?..mixer faders or contacts??
there has been much discussion on the web about it and that it will destroy..the faders of a mixer for instance... some old school technitians use it in older audio equipment.
i am not sure my self.
just i used it in my master volume fader on a samson mixer... and seems more effective than any other contact spray i have used.
ps. i have not used the well known deoxit series though....
WD-40
- ARCADIOS
- siriusbliss
Re: WD-40
Do NOT use it on music gear. Ever. Never.
WD-40 is a grunge COLLECTOR.
It's only good for old cars.
G
G
- ARCADIOS
Re: WD-40
deoxit 5 seems to be the one.... and expensive....yea..
but there are many different types of caig products and very specialized as i can see in the official site,
which is kind of confusing for which to buy as a cleaner first...(necessary 100% for removing every experimental materials(WD40) i have put) before applying the deoxit 5
advice needed..please
- garyb
- Moderator
Re: WD-40
the D5 spray is the stuff to get. it comes in a 5oz(200ml) aerosol with a tube for getting the solution where it needs to go.
use a cleaner like this first:
http://www.crcindustries.com/ei/content ... x?PN=02130
the D5 solution has a deoxidizing agent, a protectant, and a lubricant, so after you use the cleaner, you would use a small amount of the D5. for really dirty pots, contacts or switches, you can just use the D5 alone.
