Hey guys!
I bought Pulsar 2 SRB with SFP 4.5. and try to install it on Windows XP Home with Cubase SE. The Plugs were not be installed in Cubase. At each plug a windows opened were i have to write a registration code. Whats wrong, SFP was installed without problems, registration key works?
Thanks for your time!!!
Plugins not probaly instaled in Cubase SE (XTC Mode)
Re: Plugins not probaly instaled in Cubase SE (XTC Mode)
well, if it comes up with that dialog, the usual procedure is to direct it to the file with the registration codes.
there's a button to choose the file
The usual path is the Scope folder, subfolder 'App', subfolder 'Bin'...
the file is called allkeys.skf (or similiar) - it's a plain textfile, so any editor/ word processor will allow you to check what's actually in it.
The Scope distribution contains more or less all plugins available, and you may not have all required keys.
There's one key for the Scope basic software and various keys for single plugins and/or bundles.
2nd hand sellers aren't always (fully) honest in this regard...
best if you look at the file first and if something is unclear post which devices you want to install
occasinally the registry system gets confused - (some) anti virus software was a safe bet some years ago...
"well, if it comes up with that dialog, the usual procedure is to direct it to the file with the registration codes." This i have done, but it don`t work.
I deinstall spybot and adware and try again. But it don`t work too. Did this programms something in the backround that makes the installation impossible although this programms were deinstalled?
Than i have to install a new windows!?
Thanks,
topshit
Thanks,
topshit
it's not very likely that Windoze is spoilt to a degree that makes Scope installation impossible.
Did you run Scope in it's native (SFP/non-XTC) mode ?
The most straight forward approach is to do just that first, check that all IOs and the plugins are running and THEN proceed with XTC setup.
For the latter you load a Scope project with the devices and IO modules you want to use in XTC mode and save the project as your XTC project. When in XTC mode you don't have access to the Scope project window, that's why you have to do the setup in SFP mode.
It's not a plugin-and-go scenario, has never been...
If you're new to the Scope environment, it may be worth thinking about if XTC is necessary at all for your workflow.
It's not a bad thing by itselfl, but lacks a lot of flexibility.
Scope is easy to integrate with the Sequencer via Asio (and even hardware), but the Scope mixing and mastering environment IS definitely superior to Cubase's stock devices. You'd probably have to spend a 4-figure amount to get into the same league with native processing... no kidding.
(that means... if you have the mix and master package)
You could have bought the SRB with just the basic software - then those registration dialogs will pop up again and again - for you simply lack the proper codes. Did you look at the keyfile, what's listed in there ?
It could also be the seller messed the files (you probably didn't buy it from a store recently... )
Before thinking about any Windoze related actions you really should be clear about that.
# RE8MW0F06 CW Scope Fusion Platform 07/20/11 17:12 0287F0RXRBCK1DBDLWXSXDWW8SODLXESXDLW8SXDLWXN4EB
# RE8MW0F06 CW Main Studiotools Package 07/20/11 17:12 0CYLH06CH69R5D4F5Y6R6FYYJRCF562R6F5YJR6F5Y63PT2
# RE8MW0F06 CW Mixer Package 1 07/20/11 17:12 04HTB0ZX7E27RCDYJRICIYRR6CEYJENCIYJR6CIYJRIG7UM
# RE8MW0F06 CW Mixer Package 2 07/20/11 17:12 0HA5B0T29ET88DFJR6EIEJ66CIBJRBVIEJR6CIEJR6E7HM3
# RE8MW0F06 CW Synthesizer Package 1 07/20/11 17:12 0FKT80MY6ATTHEADLWXSXDWW8SODLFSSXDLW8SXDLWXN4EB
# RE8MW0F06 CW Synthesizer Package 2 07/20/11 17:12 04KA401CBW172DDDLWXSXDWW8SODLFXSXDLW8SXDLWXN4EB
# RE8MW0F06 CW Effects Package 1 07/20/11 17:12 0910F08HAL6M0E2JR6EIEJ66CIBJR0UIEJR6CIEJR6E7HM3
# RE8MW0F06 CW Effects Package 2 07/20/11 17:12 087FE04CKZW2BF0SXOY5YSOOF5JSXRN5YSXOF5YSXOY2UN4
# RE8MW0F06 CW SCOPE 4.0 Software 07/20/11 17:12 0GZ5B08GE2TX5D6XOFJYJXFF5YRXO6TYJXOF5YJXOFJUM4V
# RE8MW0F06 CW GraphEQ 07/20/11 17:12 0KKCW0T62CXF8EEYJRICIYRR6CEYJ6VCIYJR6CIYJRIG7UM
# RE8MW0F06 CW Master Verb Pro 07/20/11 17:12 0A3RL0MFL7X95D9LW8OXOL88SXFLWX0XOLW8SXOLW8O4VB0
# RE8MW0F06 CW OptiMaster 07/20/11 17:12 09WXF02H70Y52DFJR6EIEJ66CIBJRIPIEJR6CIEJR6E7HM3
# RE8MW0F06 CW Poison FM 07/20/11 17:12 0CGX602BLGW11F1LW8OXOL88SXFLWSEXOLW8SXOLW8O4VB0
# RE8MW0F06 CW PSY Q 07/20/11 17:12 0T21Z0K8FHG20DBLW8OXOL88SXFLWXEXOLW8SXOLW8O4VB0
# RE8MW0F06 CW Vocodizer 07/20/11 17:12 016KM09L15754DB5YJC6C5JJR6I5Y6V6C5YJR6C5YJCPG2U
# RE8MW0F06 CW Vinco 07/20/11 17:12 0LM0A0M1B0K5RD15YJC6C5JJR6I5YCC6C5YJR6C5YJCPG2U
This are the entries in the allkeys file. I could install Scope Software 4.0 and 4.5 with this file!?
Many years ago i owned for a short time a big creamware card and the XTC mode runs perfect after installing the software without any modification. I tried to use the Scope Platform, but it was so complicated for me that i only use XTC Mode.
cheers Mischa
cheers Mischa
- the19thbear
did you tick the "enable XTC mode" in the scope platform?
DId you make sure to have the scope platform closed when you open your daw?(cubase etc)?
Do you get the XTC logo when you open your daw?
could you please post a screenshot of you xtcproject.pro file?
My first screenshot, maybe it works...
- Scope.doc
- (306.5 KiB) Downloaded 87 times
did you tick the "enable XTC mode" in the scope platform? YES
DId you make sure to have the scope platform closed when you open your daw?(cubase etc)? YES
Do you get the XTC logo when you open your daw? late by loading the optimaster, after that the first question for a serialnummber pops
My screenshot is in a word document. No time to do it better. i have too children 2,5years and 4 month. Thats the reason wy i wont to use the XTC Mode-i have less time
Maybe someone can post a xtc project wich works?
Thanks, Mischa
Thanks, Mischa
- the19thbear
the project looks fine. And i really dont know why the pop up message appears.. i would say uninstall an install scope again. it sometimes gets corrupted.
Good luck!
I have a 2 year old and a 4 month old as well!
Good luck!
Hey brother!
Maybe its a cubase problem?
