MIDI Play/Stop/Cont/Reset in SCOPE
Post by jksuperstar »
I'd like to use SCOPE as my MIDI clock generator. So I'd like to be able to send any MIDI Realtime commands, also. I'd also like for those realtime commands to be under MIDI CC control. I sync Ableton Live to it, along with the whole studio, but Live looses all control over start/stop when it's under external sync.
So far, I can generate a Clock within modular, but is there a device to do this?
The Modular Clock doesn't seem to have any start/stop control (sending these messages), even when using the seq control module (start/stop) connected to it. Or just as importantly, a "reset" (return to position zero). The Sequencer Remote device only seems to send CC messages, not actual Play/Start/Stop messages.
The ModIV VST and associated plugin work fairly well, but not jitter-free. So I'd like to stick with the clock coming from SCOPE.
tgstgs
Re: MIDI Play/Stop/Cont/Reset in SCOPE
Post by tgstgs »
i used this once for testing
win x86 only
hope it helps vibes
_
MBeatAdd.zip
(23.19 KiB) Downloaded 380 times
tgstgs
Post by tgstgs »
_
coding on the fly . . .
if it helps -> good
else -> sorry
good vibes
MTick.zip
(20.05 KiB) Downloaded 373 times
Can these be used if the driver disabling signature is disabled..?
I will give these a go! Thanks, thanks, and more thanks!
I realized what I've been calling "reset" is actually Song Position Pointer (along with 14bits of position = 0). I work with 2 other musicians, and we've developed a style that is more DJ like...we don't stop the music: we take turns bringing sequences in & out to do song transitions. In the process of doing that, we need to resync multiple sequencers to the same downbeat, and sending a Song Position Pointer just before the downbeat of beat 0 does that for us (when using my QY-70 as the master clock, we hit the [|<] button in time, and that resyncs things when a new beat is loaded). I've found all sequencers still respond to this message even though they are still playing (but don't typically respond to a Start message once already playing.)
Is it possible to get a button with the sending of Song Position Pointer (=0, but maybe having it settable is better), that is quantized to just before beat 0?
Also, is the MTick the 10ms Midi Tick (0xF9)? I've never really made use of this...what good does it do, when 0xF8 is available as the MIDI Clock (24ppqn)?
Someday when there's an SDK for the XITE, I hope to give somethings back. Until then, I'm really glad people like you continue to give so freely. Muchas Gracias!
tgstgs
Post by tgstgs »
no x64_
i hope i find some time tomorrow for a x64 compilation for you;
the f9 is much more exacter than f8 in computer world;
i do not understand_
just tell me what hex do you want to send per button click?
good vibes
MIDI Song Position Pointer
0xF2 0xD1 0xD2
For start of song/pattern, D1 = 0x00, D2 = 0x00.
Song Position Pointer is like the Program Counter in a CPU. And sending this message is like issuing a JUMP to the CPU.
D1 and D2 form a 14bit number, just like a pitch wheel message. Together they indicate where a sequence is in terms of beats from the start of the song. Sending a message of all "0000" means go to the beginning.
More detailed info here:
http://home.roadrunner.com/~jgglatt/tech/midispec.htm
tgstgs
Post by tgstgs »
http://forums.planetz.com/viewtopic.php ... 67#p266267
take the midiMG to send whatever midimessage you like__
good vibes
edit :
for some reason the link do not focus on the zip;
its in my first post in this topic
tgstgs
Post by tgstgs »
here is the x64 driver for the MBeatAdd_
good vibes
x64.zip
(7.83 KiB) Downloaded 369 times
Ankyu.
Works in x64..
