Here is a small pack with 6 devices I've implemented. Simply copy them into your device folder.
MS-Encoder
MS-Matrix
Input Swap
Output Swap
Stereo Inverter
Peak Meter
Enjoy
							Free Software Pack
Free Software Pack
				- MyDevices001.rar
- 6 Tools for you
- (279.63 KiB) Downloaded 957 times
						Re: Free Software Pack
When I select "Yes" and click on vote this message appears: "The submitted form was invalid. Try submitting again."
Thanks.
Everything works.
While preset capability isn't crucial with these devices, having MIDI CC capabilities for the input and output swapping devices would be a nice update for the future.
Nice to see someone creating and sharing again.
The meter color choices were a nice change.
Thanks Much...
						Everything works.
Thanks Much...
				irrelevance
Downloaded and can't wait to try. Thank you.
@JAV Not sure but could Alfonso's modular stereo switches be able to swap i/o with a cc command?
courtesy of cwmodular.org:
and then you've got the Mod IV stereo switches that look like they can carry out that duty too. So many devs!!
Thank you. Great devices!
Tested in Scope PCI 5.0 32bit.
Bit exact (difference: -180 dB):
- Inverter Stereo
- Output Swap
- MS-Encoder -> discrete MS-Decoder (Inverter Stereo -> MIX2S)
Not bit exact:
- Input Swap (difference: -128 dB)
- MS-Encoder -> MS-Matrix (difference: -168 dB)
Bugs:
- MS-Matrix induce tiny sound changes (probably the +6 dB stage at the end)
- MS-Encoder can not loaded as insert effect (Invalid Module: Sorry - only insert effects can be used here!).
Greets
- Inverter Stereo
- Output Swap
Not bit exact:
Bugs:
Greets
Back again in this forum...how are your experiences with the software?
				gruebleengourd
Thanks so much for the devices.  So far I've only patched in the VU meter, but it's great!
