No ASIO SCOPE in CUBASE to choose!
ArtemArtem
Post by ArtemArtem »
Got Scope installed, however Cubase doesnt see scope asio.
Please advice. Thanx
ChrisWerner
Re: No ASIO SCOPE in CUBASE to choose!
Post by ChrisWerner »
Are the ASIO modules in your Scope project loaded ?
If this is your first Scope card, walk through the manual at your side, chapter recording.
Not that I won't help you but setting up scope on your own with the manual only has a better learning curve.
ArtemArtem
I am experienced user for 6 years already.
ArtemArtem
I formated my hard drive, setup win xp sp2, but as soon as I got Scope installed after the 1st launch i got application error and cubase didnt want to define asio scope as well. Never had such problem before.
ChrisWerner
Well then sorry.
Have you checked if there are any conflicts with the scope card in the device manager of windows?
ArtemArtem
No conflicts, IRQ is ok. It seems I have problems with installation, cos I cannot uninstall it as well.
vascomusic
Post by vascomusic »
I had the same problem in Wavelab and Cubase.
It appeared that the Scope wordclock was not locked because is was set to Slave wordclock mode (for whatever reason)..
Try to launch the "IO enabler" program. From Start menu -> Scope Platform -> IO enabler
And set the desired amount of ASIO inputs, outputs and midi ports. Then restart scope, put some ASIO source (and dest) modules in the project and start cubase
This is from a topic here :
http://forums.planetz.com/viewtopic.php ... er#p239071
