useing vst in scope
Compare notes on how to get the most from Scope devices, etc.
cjgo
useing vst in scope
Post by cjgo »
Hello.
I have unzipped a vst zip file to the plugin folder on my scope.
should'nt I be able to open the device from there and place it in my routing window.
right now I get a very quick hourglass then nothing.
also what is xtc mode...
J.
the19thbear
Re: useing vst in scope
Post by the19thbear »
No. You Can only use scope plugins in scope. The plugins run on special processors on the scope card and they Can only run scope plugins.
Xtc mode is when you use the scope plugins inside cubase/reaper etc. But i Think you should play around with scope first to undrstand the concept. Then we Can talk later about xtc mode. :)
Heres a quick blurb about XTC mode.
http://www.hitfoundry.com/issue_04/cub_xtc.htm
View ScopeRise latest issue at www.hitfoundry.com
