"direct mixer out" set to scope p-plate not remembered
Discuss Scope XTC mode.
ARCADIOS
Post by ARCADIOS »
in xtc mode the direct mixer output settings are not kept.
is there a setting i must do.
i remember that in the past the xtc ully was also not kept but it was solved after modifying the cset.ini
what about the direct mixer output, which i can select once i open the daw...but after restarting the daw it is blank..and needs to be set again.
ARCADIOS
Re: "direct mixer out" set to scope p-plate not remembered
Post by ARCADIOS »
solved by setting asio out to "direct mixer" in and then "direct mixer" out to scope analog dest.
what is exactly the direct mixer module in xtc?
fraz
Post by fraz »
Hi I think its the "Direct Play Mixer Container"......
