Hello,
Just on my first steps with the B4000.
I'm playing on a piano keyboard 88 keys.
Using the regular presets the upper / lower split is usually put on F#3
But this is bang in the middle of the keyboard, this doesn't seem right to me.
Any piano player using B4000? how do you do it?
nmp
Splitting th B4000 on a piano keyboard?
Re: Splitting th B4000 on a piano keyboard?
Use the plug-in editor to adjust the split settings the way you want it to be ... from what I remember.
Hello Hurolura,
When reading back my own post, it's seems my question wasn't clear.
I know how things are done technically using the software.
What I actually wanted to ask where is a good point to split on a piano keyboard?
One octave below middle c?
And do you put the octave parameter in the editor for the lower manual the same as the upper or put it 1 or 2 higher?
Or do you have to say, as you do not have a double keyboard as the B3 has, maybe it's best not to split at all.
And apologies if this is a bit of a stupid question, but we don't have that problem playing piano now do we?
it doesn't matter where you split it or if you split it at all - it's all up to your personal preferences or what pleases you most.
But for an authentic handling you need an organ keyboard.
There are a few models by Yamaha (Electone) that are quite light and detachable from the stand/amp construction which often show up in 2nd hand deals.
Those provide the proper midi control including footpedal for just a few bucks.
It's not only the splitpoint but also about the spring-loading of the keyboard.
If you have the space they make a great controller for (say) $100-150 - like this model
Or you can "built it yourself" by using something from Doepfer for such purpose:
http://www.doepfer.de/home_e.htm
See the D3/D3m elements
Well,
I'm not intending on bulding an organ.
But the links you sent sure where interesting.
Well I noticed that the organ keys are in fact bang on top of each other, I suppose this can never be 100% on a piano keyboard.
In the mean time I did remove all of the F#3 that is used in all of the plugiator presets.
Now there is either no split, or just the left most octave and a half for bassline.
We'll see where that get's me.
nmp
nmp
slammah2012
i guess its different using the plugiator or the b4000 asb....nmp wrote:Well,
nmp
with the b4000 asb you can select different midi channels for upper lower and pedal, so any controller with a multi mode will be able to store different midi ranges on a song per song basis...
on my controller i generaly like crossing over at e/f below middle c.... and as a rule i always lower my upper split down an octave and raise my lower split an up octave...this uncovers some ranges for both manuals and if i have to, my arms will spread apart to reach the zones i dont normally play in...
Time has No Master.
*NOW* is the Password.
Just *ASK* and *INVITE* every-
thing you are after..........
