Can,t load STS
Talk about the STS series of Creamware samplers.
koncur
Can,t load STS
Post by koncur »
When i try to load any of STS i have this: Can,t find DSP file MVC STS 5000 VxD- Please check installation
Reinstall don,t help!
julian
Re: Can,t load STS
Post by julian »
this is some weird problem with windows "blacklisting" drivers for some reason :-/
try the following
Important! Window 7 sometimes stops the loading of drivers,
allthough you have updatet them. in those cases you need to
delete their entry in the registry:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services
This can happen to files of the Sys folder e.g. "MidiAck.sys".
Search there for Scope and look for the ...*.sys files, which have the Scope installation path.
Delete all entries and overinstall again.
if this doesn't help you can have a look in your ./app/sys folder
there should be a file
MVC2VxD.sys
just try to rename it.
then it should probably work.
julian
mausmuso
Re: Can,t load STS
Post by mausmuso »
hI There,
I am experiencing this issue with the 64 Bit Beta on Win 7 64 bit machine.
I have tried the registry fix but to no avail.
Has anyone been successful?
I get errors on all STS's and VDAT loads - can't find certain files.
Maybe I am not following the instructions properly?
In the registry area nominated I find only one scope related .sys file with an install path.
I deleted the whole entry, but upon re-install, I have the same issue.
Any advice?
Regards
Maus
t_tangent
Re: Can,t load STS
Post by t_tangent »
If you run Scope in Administrator Mode then it should work fine.
Unfortunately if you do run in Adminstrator Mode then you cannot copy samples from windows explorer directly to the scope STS window.
But running Scope in Admin mode does allow the sys and vxd files to load correctly so that seems to be the only way at the moment.
Re: Can,t load STS
t_tangent wrote:if you do run in Adminstrator Mode then you cannot copy samples from windows explorer directly to the scope STS window.
How about starting an explorer in Adminstrator Mode, too? Maybe you can add a modified shortcut to desktop/menu for explorer.exe, especially for that?
t_tangent
Re: Can,t load STS
Post by t_tangent »
damn good idea atom...hadnt thought about that....DOH!!
Will try that out so thanks for the tip :)
A classic case of when 2 heads are better than 1 :)
t_tangent
Re: Can,t load STS
Post by t_tangent »
Using SONIC_CORE_SCOPE_XITE-1_v5.1.2708-RC2_EN on Windows 7 Pro 64bit
I have just checked this out and although I am able to load STS 5000 fine without having to run Scope in Administrator mode, I am having the same type problem when trying to load any of the G.O.S.T. effects devices. Even though the relevent .sys files are in C:\Program Files\SCOPE XITE\App\Sys, when I try to load the device in the routing window I get the same type error
For example when loading G.O.S.T. Dynomic effects device, I get the error
"Can't find DSP file tgsxDynomic - Please Check Installation"
I have also checked the registry and those sys files do have an entry in HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services
So for example the above tgsxDynomic.sys file has following reg entry:
Windows Registry Editor Version 5.00
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\services\tgsxDynomic]
"Type"=dword:00000001
"Start"=dword:00000003
"ErrorControl"=dword:00000000
"ImagePath"=\??\c:\program files\scope xite\app\sys\tgsxDynomic.sys
"DisplayName"="tgsxDynomic"
"WOW64"=dword:00000001
But if I remove that entry, as suggested by Julian, it makes no difference and the error still appears.
I tried running Scope as Administrator but that also doesnt make a difference
I get a similar error for all the G.O.S.T devices.
Any help would be appreciated. Thanks
julian
Re: Can,t load STS
Post by julian »
I'm sorry to say that 3rd party devices using .sys files won't work at the moment :(
for the x64 OS all sys files have to be recompiled using x64 compilers.
so far we only recompiled the SC .sys files
3rd party devices will be adressed when the basic system is up and running (all SC synths and scope features)
julian
t_tangent
Re: Can,t load STS
Post by t_tangent »
Hi Julian,
Great to see you on this forum nowadays with info direct from SC :)
Thanks for the reply, and its good to know that you are aware of this issue. Will wait for the fixes when they are ready :)
All the best
Tim
Re: Can,t load STS
Just realized having the G.O.S.T. Harmonic bundle myself that I can load the devices and still use them reagrdless of the error messages I see.
I do not know how to explain these technical issues, but I do know my devices I have missed for months actually work, so no longer do I pay attention to the pop up windows. I just plow through them now.
t_tangent
Re: Can,t load STS
Post by t_tangent »
Hi Jimmy,
Regarding G.O.S.T Harmonic Bundle I have noticed that my there are several .sys .vxd .dsp. etc types files that were installed when I was using Scope SONIC_CORE_SCOPE_XITE-1_v5.0.2619_EN_NFR.exe. This is 32bit which I had previously installed on my Win7 32bit partition
I made a backup copy of Scope XITE folder to refer back to and then uninstalled Scope and installed the latest version SONIC_CORE_SCOPE_XITE-1_v5.1.2709-x86_EN.exe
I noticed that the G.O.S.T. devices were giving missing file errors on loading, so I checked the various folders in the Scope XITE/App directory and when comparing it against the backed up copy from previous install and was able to copy them all over from the backup. Most of the files are related to 3rd party devices so its not really a problem as such but just thought I would mention it in case anyone else finds themselves getting missing file errors on loading a device and not knowing why.
I havent tried yet in 64bit partition as I am still getting audio dropouts/crackles for some reason so havent bothered checking more on those devices yet, so I am not sure if that will help.
Cheers for now
Tim
ARCADIOS
Re: Can,t load STS
Post by ARCADIOS »
sts samplers are toooo tricky and buggy
lagoausente
Re: Can,t load STS
Post by lagoausente »
I think STS don´t work on 64 bit, I get BSOD, and reply of SC was "sorry we´ll try to fix STS..." so seems it don´t work.
