filling in the "upgrade gap"... !!??!!
Gary_101
Post by Gary_101 »
hi folks,
I'm slowly getting back on board with my Pulsar I & II configuration. Thanks to all of you for the valuable bits of info I've gathered here over the years about technical obstacles, configuration, etc.
I work with video editing as a hobby, and may be soon upgrading to the mystical world of HD video; many are recommending that I upgrade my P4-3.2 GHz - 2gig ram XP-pro system to a dual-core 64-bit system, to handle the rigors of HD video. I'm hoping to find an ATX motherboard that will fit my current footprint, so I can keep my current box with fasttrack raid/SATA array in place.
Anyway, if anyone has simple answers to these questions, would be much appreciated.
  • I have a Pulsar I which I purchased (way back), about 1999, and a Pulsar II purchased around 2005, which I run in parallel. Can I still do so on a 64-bit system?
  • Will my current SCOPE OS (4.0) run on a 64-bit system?
  • If an upgrade to Sonic-core's latest SCOPE OS is necessary for 64-bit compatibility, which version do I need?
  • Does anyone have a ballpark guess at the cost of the SCOPE upgrade necessary?
  • Can anyone recommend a good ATX 64-bit motherboard that will work well with my Pulsar I & II (and perhaps, HD video to boot?) :)
Thanks for any and all feedback / comments.
BTW, I don't a lot of processor-intensive audio work ... at most a few tracks of stereo audio + a few midi at once. My HD video productions are not major works either, mainly short abstract & hobby pieces, so I don't the "Xeon-Of-Xeon's" as far as processing horsepower goes. This is more hobby-based, not professional sound studio.
Gary
Re: filling in the "upgrade gap"... !!??!!
I would get the Triple Channel RAM and a cheap i7 930 rig.
I recently built another DAW w/ 12GB's and can do whatever I want now as far as loads and processing power.
I overclocked until I hit 62C which was around 3.3GHz on stock HSF.
Video and Audio share the same IRQ and no troubles after a few OS tweaks.
No need to spend a bunch of bread, save that for hardware or plugs...
bosone
Post by bosone »
and you MUST get SFP 5.1 to get 64 bit drivers.
it exist, but it is still in beta!
contact sonic core for informations... they will reply to you soon! ;)
Gary_101
Post by Gary_101 »
thanks guys ...
is soniccore's beta 5.1 backward-compatible for 32-bit systems as well?
w_ellis
Post by w_ellis »
Not currently, no.
