Joined the forum while awaiting my plugiator that is being shipped.
[The poor mans Xite
I wonder if any 3rd party plugins are being developed, or is this all strictly use-audio ?
Regards,
nmp
thats really unfortunate.... especially since thereare 800 user save slots on the hardware you can access without any computer assistance...siriusbliss wrote:Yes, Mike was attempting to use Live for sequencing and tracking the Plugiator, and couldn't maintain linkage.
He was unable to load his patches.
the only problem i ever experienced after going to 2.0 was i had to update my flashplayer so it would function like the earlier model.... the early version worked fine for me on an xp pc...nmp wrote:Well, I'm glad the plugiator exists.
But you'll have to say that if nobody tell's you what it's about, you'd overlook it in the shop.
It doesn't have the sex-apeal to lure to it and play with it in a store.
I actually never seen one in a store, so that proves the point of overlooking it (or they just don't have one)
When it arrived i was actually pleasantly surprised, it's not as ugly as expected and built very well and steel, not plastic!.
I was a little dissapointed the first couple of hours when connecting it to a PC getting it updated + getting some of the online sounds into it. 2.0 doens't allow to drag online sounds & 1.01 doesn't show the control panel on my PC & then software keyboard doesn't work (other communications with the plugiator do work... PC and Plugiator do see each other).
So I had to get them both installed to use all functionallity.
I hope these troubles are specific to my PC (Win7).
I found out that you can install 2nd & 3rd instances of a plug on the 4 free slots, getting you more available presets.
So getting the plugiator configured the way I wanted to I disconnected it from the PC, and it may not get connected again in the near future.
Then then I connected it via Midi in my setup, and only then I started to realize that this white breadbox can make some seriously inspiring noise.
It's not leaving anymore.
So if Use-Audio is designing the Plugiator 2 they should concentrate on the packaging to lure the gearheads in the shop to it ...
For instance the little Arturia keyboard that they give with the analog factory software has this appeal -> it makes it stand out in all the other software packages. And even if you really do not need another controller keyboard, this one is so cute that you might walk out of the store with the software package... even if you're not interested in softsynths.
http://www.arturia.com/evolution/en/pro ... intro.html
A plugiator in a thing like that would really sell ...
i can't recall what my initial problem was.... but the first version worked fine for me.... then i updated to 2.0 and every thing malfunctioned... i even lost presets...but after contacting useaudio, they gave me a link to a version of flash player that didnt clash and that fixed everything.... luckily, my online user presets, were still up online and i recalled them.... contact useaudio.... they will set you straight..nmp wrote:Can you drag on-line sounds into a bank with your 2.0?
[That is the only thing that doesn't function for me in 2.0, and I do not know if it's the application or something else on my PC causing this.]
No, the appropriate time will be when I see some actual movement, not speculative "market-speak".HUROLURA wrote:Appropriate time would probably be Namm Show or MusikMesse ...
