Scope 5 right click (context menu) devices missing
irrelevance
Post by irrelevance »
I seem to remember having this problem come up with previous versions of scope so it's nothing new. But when I right click to insert a device in a mixer the box with insert appears but hovering over the insert doesn't bring up any devices so the only way I can do it is by dragging in from the toolbar menu. Funnily enough once the device is loaded right clicking and hovering over the surfaces dialogue brings up the options to close, open panel and presets. Can't remember if I have to change something in the cset? Any ideas?
irrelevance
Re: Scope 5 right click (context menu) devices missing
Found some incorrect paths in the cset.ini reference resolver and changed them to the correct paths (still had old install paths) but this hasn't made any noticeable difference. Still trying... :roll:
:o
never seen that one...
i'd try running the installer over the top of the old install and then i'd backup your device, dsp, sys, project and preset folders and start over if running the installer won't fix the problem.
irrelevance
I'll give it a try and let you know ;) nice one gb.
irrelevance, do you have a similar entry in cset.ini?
Code: Select all
[StaticPath]
Effects=D:\Scope5/Devices/FX/
Btw, what's with Scope and its slashes? :D Looks like a merger from *nix and Win...
irrelevance
at0m you beauty that's the one! :) 8) updated this info and solved. thanks! Yeh I always thought those slashes were odd too...
