The Scope ASIO driver in versions 4.5 & 5 does not work with Sibelius 5.25. I think I read somewhere it doesn't work with Sibelius 6 as well. Can anyone confirm this (I don't have version 6). I'm stuck to using the ASIO4ALL driver in parallel with the Scope ASIO driver.
What about Finale - does that work with the Scope ASIO driver? To be honest, I probably won't consider changing notation package just for an ASIO driver - the mock ups are done better by exporting the MIDI parts from Sibelius into Sonar anyway.
Presumably, it is Sibelius's problem...not Sonic core's
Does anyone have further information / experience on this?
ASIO Scope drivers and Sibelius.
- dante
Re: ASIO Scope drivers and Sibelius.
Cant test myself as dont have Sibelius or Finale. But heres a related Sibelius thread :
http://www.sibelius.com/cgi-bin/helpcen ... 3&&guest=1
One workaround here quoted :
I'll keep an eye on this if you fix it I'm gonna start tracking these types of things for future ScopeRise inclusion.Søren Jepsen wrote: I've had a bit more time to test it now. I can get ASIO working (most of the time), IF I start Sibelius with the asio4all driver, end then switch to SCOPE. Then before closing Sibelius I switch back. If I don't switch back, Sibelius hangs on startup as described (and mentioned in the leaflet from the Sibelius box).
- sonicstrav
Thanks for that. Great link - I'll try that out.
I think it more a problem with Sibelius than Scope, though
Cheers
Cheers
- dante
If the workaround above works, then suggests Sibelius/Scope issue is at Sibelius start-up only, not if you change once Sib already open. Let us know how it goes.
- sonicstrav
Hmmmm....it doesn't work
Oh, well - I'll just keep using ASIO4ALL now
BTW - Notion 3 works fine!
- valis
Were ALL of the different ASIO drivers tried (ASIO1/2 16/24/32bit) with and without the somewhat recent cubase patch?
