  ....) ,I plan to control my Noah EX with a hardware synth via Logic (hey, my Noah works perfectly with osx 10.5 !
 ). To be honest i am not sure many people here have the same set up but here is what i want to do : map my hardware synth so that it can match to the fixed midi cc of the Noah. Why ? Because a good synth has better knobs, good keys and gives you additional sounds if you compare it with all the cheap (or expensive) controller / keyboards in the market. Furthermore these keyboards (Akai, Novation, ..) need a software to run and to mapp the midi cc (what about the forthcoming updates then ???).
 ). To be honest i am not sure many people here have the same set up but here is what i want to do : map my hardware synth so that it can match to the fixed midi cc of the Noah. Why ? Because a good synth has better knobs, good keys and gives you additional sounds if you compare it with all the cheap (or expensive) controller / keyboards in the market. Furthermore these keyboards (Akai, Novation, ..) need a software to run and to mapp the midi cc (what about the forthcoming updates then ???).What i plan to do :
- avoid a dedicated controller (ex : BCR2000) and use a regular hardware synth abale to send midi data to the sequencer
- use the environment transformer objects in Logic (you can change any midi data into another)
I will work on that project this summer but any input is welcome of course. First of all, WHO is using OSX with a Noah ?
Thanks,
Jo
