using midi controller with Pulsar 1
Malascope
Post by Malascope »
I need to buy a new keyboard & I'm thinking if I buy a midi controller connected via usb I may solve the latency problem I have with my Pulsar 1 which is 25 ms.
Would I be correct?
And can the keyboard midi connection appear in Scope?
Malascope
Re: using midi controller with Pulsar 1
Post by Malascope »
Ok thanks for that stardust. I have an Asus P5b-e & can't reduce the latency to 13 ms so it's obviously not a decent mainboard.
Actually that's not the only problem I have with the Pulsar on this mb so I wouldn't recommend it.
it's probably a setup issue, but even 13ms is 24ms from controller to the sequencer and then back(if you're playing vstis). get a newer card, even a Luna, and you'll be able to do 4ms or so.
i'd be happy to assist in the setup, privately. phone or skype would be easier and faster....
Malascope
Post by Malascope »
That's very generous of you Gary. I'm located in Australia so I'm not sure what's best timewise for you but skype is probably a good way to do it.
What time zone are you in?
pst
Malascope
Post by Malascope »
Ok so I'm 15 hours ahead of you Gary. What's your best time timeframe?
between 1 and 5pm or the 11pm-3am range, though i have to make time for it either way. we should move this to a private message.
