I have a couple of projects that I broke somehow and cannot figure out how.  In each of the projects I have some midi controls that do not work correctly.  I set the controller number and they work.  But when I save them and restore them then quit working and I must re-assign them. (not all controls give me problems.)  The midi channels are save in the parameter list but I have no prest list.  I tried saving the CtrlNbr in the arguement list but that does not help.   The saved value shows up in the controll, but only works after I unset the control number and reset it again.
Any ideas?
							Help, midi problems
Re: Help, midi problems
I still have that problem too.
I thought I had fixed it by placing a ( - ) in front of the MIDI CC Bank so it would occupy the very first place in a preset list.
After that I just recall presets by using note on/offs on nn:60 - nn:128 of a zone that an Analog SYnth Bass uses nn:000-059.
It seems to work on everything except Modular for me atm.
Try placing the MIDI CC Bank as the first in the preset list and see if that works.
Ciao
Ciao
- FrancisHarmany
are these the same controls each time ? same CC each time ? same device ? or all random ?winger wrote:I have a couple of projects that I broke somehow and cannot figure out how. In each of the projects I have some midi controls that do not work correctly. I set the controller number and they work. But when I save them and restore them then quit working and I must re-assign them. (not all controls give me problems.) The midi channels are save in the parameter list but I have no prest list. I tried saving the CtrlNbr in the arguement list but that does not help. The saved value shows up in the controll, but only works after I unset the control number and reset it again.
Any ideas?
I was using a Master fader control(not sure if this is the exact name.  Big vertical fader with markings for fader positions on the GO.  I deleted it and added it back in, no help.  I then deleted it and replaced it with a different fader and now it works.  But I have used that same control in other projects successfully so I know the control can work.  It is a mystery to me.
							mark winger
