Hi all,
I want to connect and external device to the above and it appears to have a 3.5mm mini jack socket - is this an optical connection?
Si
Scope Home S/PDIF
- grappa
- at0m
Re: Scope Home S/PDIF
No, you can insert a "3.5mm jack to cinch" cable there...
- garyb
- Moderator
...or an adaptor with a proper impedance sp/dif cable attached....
- grappa
Thanks guys,
I am coming from optical so will need to get a converter and then go into my Scope Pro card.
Appreciate your help.
Simon
Simon
