I want to use midi note number to select which input to select on a Signal Switch EX.  I have it set to receive note on from all channels.
YOu can select output databye1 or databyte2.  Then you can select observe value.
It does not matter what midi input I send it,what byte is use for output, the observe value is always 10.
Has anyone ever tried to use this "midi value extractor" successfully??
