Exchanging ASIO modules doesn´t work
es1276
Post by es1276 »
I´m trying to replace the ASIO24 bit modules in my projects with ASIO2flt.
The manual says:
modules and their connections can be exchanged by dropping the new module over the old one, while holding the <ctrl> key.
But this doesn´t work in 4.5 on my WindowsXP machine.
The module is replaced, but the new module is without any connections.
What am I doing wrong ? :-?
Thank you.
es1276
es1276
Re: Exchanging ASIO modules doesn´t work
Post by es1276 »
Could anyone please check if this is a problem in version 5 too ?
Thank you.
es1276
it's not that hard to delete the old module and then drag and drop the new module and reconnect it. you can't change modules with the sequencer open and there's not reason to swap them all the time, anyway. i think that tip is VERY old...
es1276
Post by es1276 »
Yes, if you speak about only one project and you don´t use a lot of source and destination modules, it is not hard.
But if there is no other chance, I have to do it that ´VERY old´way. :wink:
Thanks Gary.
yeah, sorry...
