Scope DSP File VST PlugOut Vxd Error Windows 7 ' Solved '
microraver
Post by microraver »
Hallo,
I did a fresh install windows 7 32bit, then installed SCOPE PCI v5.0.2617 (ENGLISH VERSION) with vst integration, reboot pc ,
exit the Scope PCI manager, start Cubase 5.1.1.120 .
The most Scope plugins loads ok, but all the Scope synth plugins and a few others give me Scope DSP File VST PlugOut Vxd Error !
See Picture.
Scope DSP File VST PlugOut Vxd Error.jpg (79.54 KiB) Viewed 1609 times
I have a dual boot with 1 harddrive win xp sp3 and a second harddrive win windows 7 ultimate.
Everything works fine under XP sp3 .
System asus p5wdh-deluxe , cpu q6600 ,4gb ram
I have tried everything , it's the first time i dont have a solution :-?
Someone with a solution ?
P.L.U.R
Cubase 5,Scope v5.1 XTC,2xScope Project+2x A16 Ultra+PoCo 6000(CL1B+Virus)+UAD2-QUAD(Comp,Rev,EQ)+plugiator Full.Mackie Control+Ext.ASUS P5WDH,CPU Q6600@3GHZ,6GB RAM,2xPCIe Graphics,4 Display's.Win 7 32 & 64bit.
http://soundcloud.com/dominium
microraver
Re: Scope DSP File VST PlugOut Vxd Error Windows 7 Ultimate
stardust wrote:did you install and load as administrator ?
VxD are drivers
Yes Everything is installed and running as admin, the strange thing is i cant find anything about this VxD , not in win7 and also not in Working Win XP !!, and i have full rights on both systems and also checked to view hidden files extension .......and most Scope VST Plugins works ! just like i said the Scope Synths and a few FX give me this error !
Also did 2 times full fresh install Win7 and scope5 !!!
P.L.U.R
microraver
Re: Scope DSP File VST PlugOut Vxd Error Windows 7 ' Solved '
Made a new XTCproject.pro , renamed the Scope PCI plugin folder and in Cubase 5 'Device setup-Asio Scope' a Reset !
Everything works now :P
P.L.U.R
davesiddons
Post by davesiddons »
Could you give a little more detail as I am experiencing the same problem. Do you create a new empty project. By plugins folder do you mean the folder under the vstplugins folder.
Cheers
