For Scope Modular fans that have Reaktor 5 I have come across this:
http://www.native-instruments.com/index ... tchid=8957
This does look interesting - it has 146 modules :-
Collection of voltage-controlled synthesizer modules, inspired by the Nord Modular G2
This is a collection of 146 types of voltage-controlled synthesizer modules, intended for patching together into instruments. It was inspired by the Nord Modular G2, still my favorite modular synthesizer.
To create a “patch”, paste the modules into an ensemble and wire them together.
All inputs and outputs are “voltages”, and follow conventions commonly used by modular analog instruments. Pitch inputs are calibrated in 1 volt/octave. Oscillator and LFO outputs are +/- 10 volts peak-to-peak, and envelope generator outputs max out at +10 volts. All inputs can operate at the audio sample rate. While this consumes additional CPU resources, it means that anything can be connected to anything.
I want to thank Jonathan Style for creating all of the custom panel elements.
The complete module list is below.
Inputs/Outputs/Diagnostics
--Common MIDI Controllers
--External Stereo Input
--MIDI Controller Input
--Panel Elements
--Oscilloscope
--Pitch & Gate Input
--Poly Note Display
--Poly Voltmeter
--Poly VU Meter
--Stereo Output
--Stereo Voice Combiner
--XY Mouse Controller
Oscillators
--32-Sine Cluster Oscillator
--Analog Oscillator
--DX Oscillator
--Formant Oscillator
--Geiger Oscillator
--Hammond Oscillator
--Noise Source
--Sample Player
--Spectral Oscillator
--Stereo 4-Octave Pulse Oscillator
--Stereo Super Pulse Oscillator
--Stereo Super Saw Oscillator
--Reaktor Waveform Oscillator
--Tuned Noise Oscillator
--Variophon Oscillator
Low Frequency Oscillators
--LFO
--MIDI Synchronized LFO
--Slow Random Voltage
--Wobbly LFO
Filters
--1-Pole Filter
--4-Pole Filter
--Classic 4-Pole Filter
--Comb - Allpass Filter
--Dynamic Shelving Filter
--Morphing Peak Filter
--Phase Filter
--Static 2-Pole filter
--Static Peak Filter
--Stereo 4-Pole filter
Equalizers
--10-Band EQ
--2-Way Crossover
--30-Band EQ
--Bass-Treble Shelving Filters
--Moog 914 Fixed Filter Bank
--Stereo 10-Band EQ
Envelope Generators
--ADSR Envelope Generator
--AD Envelope Generator
--AHDSR Envelope Generator
--AR Envelope Generator
--Envelope Follower
--Four-Segment Envelope Generator
--Modulated ADSR Envelope Generator
Gain Controllers
--db-Scaled VCA
--Gain Controller
--Multiplier -Ring Modulator
--Octave Gain Controller
--Stereo VCA
Mixers
--4-Channel VCA-Mixer-Panner
--4-Input Dual-Channel Mixer
--4-Input Mixer
--4-Input Panning Mixer
--8-Input Mixer
--Crossfader
--Panner
--Crossfading 8-to-1 Selector
--Crossfading 1-to-8 Distributor
Delays
--2-Tap Delay
--8-Tap Stereo Delay
--Cloud Delay
--FX Mono Delay
--FX Stereo Delay
--Grain Delay
--Modulated Delay
--Static Delay
--Static Diffuser Delay
Shapers
--Clipper
--Raise To Power
--Rectifier
--Sample & Hold
--Soft Clipper
--Static Sine Shaper
--Track & Hold
--Tube 3X
--Wave Terrain
--Wave Wrapper
FX
--16-Part Chorus
--4-Part Chorus
--Aural Exciter
--Bit Crusher
--Flanger
--Frequency Shifter
--Hammond Scanner
--Leslie Cabinet
--Phaser
--Sample Rate Crusher
--Space Master 2 Reverb
--Stereo Compressor
--Stereo Tremolo
--Stereolizer
Control Voltage Processors
--Constant Voltage Source
--Control Voltage Processor
--Level Shifter
--Voice-Specific Voltage Source
--Voltage Lookup Table
Pitch Processors
--Alternate 12-Note Scales
--Just Intonation Scale
--Note Quantizer
--Pitch Offset
--Octave Lookup Table
MIDI
--Send MIDI Channel Aftertouch Data
--Send MIDI Controller Data
--Send MIDI Note On-Off
--Send MIDI Pitchbend Data
--Send MIDI Program Change
Sequencers
--16-Step Dual Gate Sequencer
--16-Step Note/Gate Sequencer
--16-Step Voltage/Gate Sequencer
--8-Step Dual Gate Sequencer
--8-Step Note/Gate Sequencer
--8-Step Voltage/Gate Sequencer
--Free-Running Sequencer Clock
--Synchronized Sequencer Clock
Modal Exciters
--Modal Bow Exciter
--Modal Fan Exciter
--Modal Hammer Exciter
--Modal Scraper Exciter
Modal Resonators
--Bar Resonator
--Harmonic Resonator
--Single Mode Resonator
--Wooden Body Resonator
Waveguides
--Clarinet Waveguide
--Pipe Waveguide
--Saxophone Waveguide
--String Waveguide
Logic
--Dual Logic Inverter
--Dual 2-Input Logic Gate
--Logic Compare
--Logic Edge-Triggered Pulse
--Logic Delay
Switches
--2-Input Switch
--4-Input Switch
--4x4 Attenuating Matrix
--6-Input Switch
--8x8 Pin Matrix
The upload contains:
* AmpereV11.ens – An ensemble that includes one instance of each module.
* 11 example instruments created with the modules.
At http://electro-music.com/forum/download.php?id=20545 is a zip file that contains "AmpereV11 Modules", a folder that includes all of the modules as separate macro files, grouped by type. Copy this folder into the default Macro path, and it will appear in Reaktor’s macro browser.
							Scope Modular users that have Reaktor 5
- sonicstrav
				- reak.jpg (272.09 KiB) Viewed 6229 times
Re: Scope Modular users that have Reaktor 5
That 32 SIne Ckuster Oscillator looks awesome.
						- sonicstrav
No - I'll download it now
BTW This might interest you :
http://logiciels.pierrecouprie.fr/spip.php?article36
Its done using Max/MSP 5
Le Synthé V5 is an emulation of the mythic Synthi AKS constructed by EMS in 1972.
As an emulation, you can found the original interface (devices and matrix board), and the approximate original sounds (the waveform was recorded from an original VCS3). As a software, Le Synthé V5 adds new improvements (control device, delay effect, oscillators with more important ranges, a better system to control the device, MIDI control, memory, etc.).
				- gfhgfhgfhgf.jpg (149.15 KiB) Viewed 6127 times
updated links:sonicstrav wrote: Sun Dec 27, 2009 8:02 amFor Scope Modular fans that have Reaktor 5 I have come across this:
>>native-instruments.com/de/reaktor-community/reaktor-user-library/entry/show/6019/
Ampere Modular
V12
>>native-instruments.com/de/reaktor-community/reaktor-user-library/entry/show/6701/
Ampere Addenda
Additional modules for Chet Singer's Ampere Modular set
>>native-instruments.com/de/reaktor-community/reaktor-user-library/entry/show/8115/
[Macros] Ampere Modular+Addenda
Ampere Modular and Ampere Addenda .ens exported to macros
more up to v6:
>>https://www.native-instruments.com/de/r ... show/8091/
Allegheny Modular
UPDATE 5 FEB 2015 - 99 MODULES
>>https://www.native-instruments.com/de/r ... show/8013/
Monongahela Modular
Large Modular-X ensemble - over 70 modules!
>>https://www.native-instruments.com/de/r ... show/8811/
Block Sequencer MIDI Out
Macro to send MIDI from Block Sequencers out in DAWs
>>https://www.native-instruments.com/de/r ... how/11439/
64 Step Sequencer
64 Step Sequencer with factory Blocks modules.
>>https://www.native-instruments.com/de/r ... show/6917/
Modulo v3
Module Modulo
>>https://www.native-instruments.com/de/r ... show/8767/
Modulus v1
Modulus is a extensive modular framework with 34 modulators.
>>https://www.native-instruments.com/de/r ... show/4247/
Seq - Modulation 4x (fixed)
fixed version of the 4x sequencer from the classic modular library
>>https://www.native-instruments.com/de/r ... show/3203/
blok 001 : seq 32
32 stage data macro
>>https://www.native-instruments.com/de/r ... show/3175/
Interpolator XY
Realtime interpolation calculator
				- 64-step-sequencer.png (314.43 KiB) Viewed 4562 times
				- Monongahela_Modular.png (277.94 KiB) Viewed 4563 times
