Cable length between Xite-1 and PCIe interface
Enrada
Post by Enrada »
Hi there,
could anybody tell me how long the cable to connect to Xite-1 module with the PCIe interface is?
Thanks in advance!
siriusbliss
Re: Cable length between Xite-1 and PCIe interface
Post by siriusbliss »
about 3 feet (or a meter).
katano
Post by katano »
strange, the cable i got is about 2 meters...
i believe the maximum length was 10 meters or so. i really don't remember, S/C can verify, but it might be even longer(maximum possible length). i believe a stock aftermrket cable can be used.
spacef
Post by spacef »
-- pc card to rack = HDMI (classic hdmi)
-- SC told me they tested up to 10 meters without problem but also that it is better to stay on shorter length (in all type of connections, usb, firewire, audio, hdmu etc etc there is a risk of data loss/corruption if cables are too long). There are HDMI amplifiers but I don't how good/bad they are.
plug-ins for scope
SpaceF website
SC website
Enrada
Post by Enrada »
puh, good luck :)
I'm planning my working space with upcoming Xite-1 and connection to the PCIe interface and was worried about cable length which could mean a complete change of my planning. but HDMi standard cable with up to 10 m sound very good so far... actually, 4,5 - 6 m should be more than sufficent.
Nevertheless, I think I should have to ask also the official support on monday to make this fact sure..
thanks for your responses, I can sleep again :wink:
spacef
Post by spacef »
kind of stuff you can find about HDMI repeater (amplifiers) http://www.hdtvhookup.com/hdmirepeater.html
But I have no idea if this kind of stuff would work on xite... looks risky :-)
I think the cable is now either 1m or 1.80m (3 or 6 foot) but I don't know (that's what I read on forums)
plug-ins for scope
SpaceF website
SC website
johndunn
Post by johndunn »
The one that came with mine is about 2 meters.
Marvin
Post by Marvin »
Enrada wrote: actually, 4,5 - 6 m should be more than sufficent.
I'm using a standard 5 m HDMI cable, works absolutely perfect. :)
siriusbliss
HDMI requires a lot of power down the cable, so under 10m is the basic recommended spec.
One company I'm working with is developing wireless HDMI, and it's basically restricted to under 40m over the air.
p.s. FWIW I think LightPeak may win out over USB3.0 within 3 years.
http://www.techspot.com/news/36357-inte ... -peak.html
Currently USB 3.0 has problems with power, and there are some other hybrid HDMI protocols emerging, but ultimately if Intel decides to dump USB3.0, then Lightpeak may take over (or they could just call LP USB 3.0 :roll: ).
spacef
Post by spacef »
I think USB3 is the future e-Sata protocol, as e-Sata does not convey electricty on the same cable, so they work on that. It is the same plug shape and same bandwith (SATA III 6GB/s).
plug-ins for scope
SpaceF website
SC website
siriusbliss
spacef wrote:I think USB3 is the future e-Sata protocol, as e-Sata does not convey electricty on the same cable, so they work on that. It is the same plug shape and same bandwith (SATA III 6GB/s).
I can see this trend, yes...
Some laptops already have eSATA.
Rinse
Post by Rinse »
Our computers are in a dedicated room and I have it running succesfully with a 15 meter cable (a pretty expensive one tough)
