Hi there,
Hopefully someone can tell me what DSP file is the 'Softube Twin BF Poweramp 44.1khz'?
I found my Dynatube was not working in 5.0.2615, I checked here at 'Z and noted I needed to bring some mdl files across (17 of them) I found them in my old 4.5 Application directory and copied them to Scope PCI... Application directory.
Now when Dynatube loads it wants the DSP file I mentioned above and of course still no sound.
I checked thru my old 4.5 DSP folder and copied (one by one) DSP files that looked like they might be the right ones (files like st**.dsp) none of them worked. I then went bacik and reloaded 4.5 and Dynatube works, but reinstalling 5.0.2615 it wants this file.
Any suggestion?
maus
Dynatube wont work in PCI 5.0.2615
- luigicampala
Re: Dynatube wont work in PCI 5.0.2615
look it up in the soniccore download section.
You´ll find the files you need and the folders they belong to.
Easy as
Thank you, I guess sometimes you have to be reminded of the simplest things
all working.
regards
maus
all working.
regards
maus
King of Snake
yup finally got my Dynatube working again in v5 too
- Mr Arkadin
Does Vinco DT work for everyone? That's the only thing i haven't got working in Scope 5 (any build) yet.
Vincodt and the sts samplers asking for keys.Have the keys in the registry but it doesnt work.I dont use these plugs tho.
ah great, it's not me alone. I don't use sts5000 either, but it was the first device I came across to try with 2615, and it bothered me with that piracy dialogue many many times...Fluxpod wrote:...and the sts samplers asking for keys.Have the keys in the registry but it doesnt work.I dont use these plugs tho.
maybe I should try to get a new keyfile first. mine is from the first days of 5.0
You have to reregister VincoDT with the actual v5, Ralf Dressel told me (at least it is like that for the xite version). It should be solved in a later release. For now you have to send the request string to S|C to get a new key...
I guess it's the same with STS5000
Cheers,
Roman
Cheers,
Roman
- Mr Arkadin
STS5000 loaded fine here and i didn't ask for the key, so my allkeys must be OK for that.
Thanks guys.I am on the first v5 allkeys so i guess i just wait until they fix it.Non issue for me.
