Behringer purchases Midas & Klark Teknik
				netguyjoel
I wonder how long it will take for some of that technology to trickle down to end users...hhhhmmmmm
							Joel
						Re: Behringer purchases Midas & Klark Teknik
Gawd. This is like K-Mart purchasing Sears.
These brands will still operate seperate from Behringer which is clearly stated.It would be stupid to run midas an kt into the cheap ground because the people who use these wont be fooled.As much as i dislike some of the strategies uli brings to the table he isnt stupid.
				netguyjoel
They should operate seperately...but, the technology is what I'm referring to.
I wouldn't mind seeing an affordable 24 fader daw controller from Behringer...
That's all I was trying to say...not a $799 Midas console...
Joel
Right.They maybe grab some ideas here and there but i dunno.A 3 bcf setup is already a 24 ch solution.
				netguyjoel
more knobs (BCR), ONE UNIT, meters, transport & jog wheel...joy stick???
I'm just throwin some ideas around out loud...
Joel
Add 1 bcr to the 3 bcf.Do you really want that much stuff in 1 unit.....from......behringer?Think about it,when the shit hits the fan with 1 unit......yayks.Buy a 4x hub connect configure done.I would never ever buy such a big unit from Behringer without getting worried.But i would buy several without worrying that i sit there with a complete broke setup.(Isnt it hillarious that one has to even worry about this?...hehe)
				netguyjoel
I have (2) MX-9000 mixers and they have worked fine for years....not to mention a huge PA from those guys, I beat the crap out of it...& it works just fine...
(4) B1800X Pros (4) B1220X Pro (2) B1520DSP (2) SUPER-X PRO CX3400 (6) EP2500 amps.
I'd like to see more from them....
Joel
That is indeed a LOT of gear from them.And it shows that lots of it isnt prune to break as often reported.We have 2 pieces of b. gear the tube composer and the 4 band para tube eq.(Both arent really tube and the little bulbs behind te tubes are dead now but whatever yadda yadda).Id still would like several pieces instead of 1 big but hey,personal preference.
				netguyjoel
Yeah...I do have a BCF & BCR too...
I have found the power supplies in their low end mixers to have failed as well...
here is the PA...
here is the PA...
 Joel
Uli would be proud.  Man you have to post that on gearslutz!!!!!! lmao!
				netguyjoel
