SATA IDE Channels on Intel DP35DP
Music Manic
Post by Music Manic »
Hi guys,
I now have 3 SATA Drives and was wondering if there is a way to manually set them up so they don't use the same channel or bus.
Any ideas?
Re: SATA IDE Channels on Intel DP35DP
sure, plug them each into it's own port. they won't work any other way.
Depending on where your Full Length Pro cards are located, you need to choose the ports wisely.
If memory serves me right, I had 3 x Scope Pros, and then switched one out for a Pulsar II Type II because of the SATA connector ports.
