scope 4.5 where is the pulsar analog source and dest
asgervejlgaard
scope 4.5 problem. pulsar analog source and destination is not listed in the i/o list,what device do i use to record vokals and synths comming from my hardware mixer into scope,so that they can be recorded in logic. do they have other names now,or been replaced with some other devices ?
- Mr Arkadin
Re: scope 4.5 where is the pulsar analog source and dest
You probably just need to install 4.5 again. Either go over your current installation, or if you have no major things saved then do a full uninstall/reinstall. They should be in Hardware IOs as normal.
asgervejlgaard
thanks for helping ,so you think i lost them under the installation ,in some way?
