scope 5 crashes when virtual drive is created
ARCADIOS
Post by ARCADIOS »
when i create a virtual drive with power iso or alcohol120, scope crashes giving this:
"The istruction at"0x00b311c1" referenced memory at "0x000000508". The memory could not be "read"
click OK to terminate the program"
i wonder if it is a scope5 RC problem or it is a problem that is caused by my pc?? :-?
Janni
Re: scope 5 crashes when virtual drive is created
Post by Janni »
I think thats normal... I remember having the same expierience with older scope versions...
I just turn off scope for those tasks...
ARCADIOS
Post by ARCADIOS »
"normal"? :roll:
there should be a fix though, a tweak......
Janni
Post by Janni »
In terms of "normal" I mean for that kind of platform... I think its structure related... If you know ProTools
you probably know about it's problems with mounting and unmounting devices... With ProTools running, you are not able to unmount any device!
ProTools just blocks this and you have tp quit or use PTs unmount feature in workspace window...
I think it's not really a showstopper to quit SFP if you are doing crazy things with your harddrives... I would quit any other programm! :D
Mr Arkadin
Post by Mr Arkadin »
Man, "Doctor, doctor my arm hurts whenever I move it like this!" (waves arm in the air)
"Is there anything i can do to stop the pain?"
Doctor, "Yes, stop waving your arm like that."
netguyjoel
Post by netguyjoel »
OW...OW...OW....I think I'm gonna stop doing that... :lol:
Joel
Janni
Post by Janni »
I was using daemon tools... http://www.daemon-tools.cc/eng/home
Throttler
Post by Throttler »
for some reason, nero image drive doesn't cause any problems, but it only supports a couple of formats
next to nothing
Post by next to nothing »
http://www.slysoft.com/en/virtual-clonedrive.html
Dont know if DT has fixed their issues, but this tool always worked flawless in win7, so maybe it would work for other driver related issues.
Fede
Post by Fede »
It isn't DT's fault (nor Nero), it is Scope that crashes whenever a new CD-ROM device is created, probably because of the akai file system support (very old *BUG*).
Fede
