audio feedback problem
ARCADIOS
Post by ARCADIOS »
how can i avoid the feedback distortion of my mixer sending to scopes anolog source and getting back from scopes analog dest.
i need to use the effects of my mixer applied to scopes analog dest.
i mean without deactivating the green mix buttons
Re: audio feedback problem
the problem is in recording with a mic? use headphones.....
ARCADIOS
Post by ARCADIOS »
i wasn't clear.
it is not a mic problem.
i send scopes audio outs to the mixer in order to be able to pass it through mixers effects and at the same time hearing the result without green mix scopes mixers buttons turned off. i want them on.
Jah Servant
Post by Jah Servant »
If you are using effects from your mixer on your track and you want to send it back then you only need to hear the input coming back into scope, turn off the channel you are sending out so you don't hear it, that's the purpose of having the green buttons, so you can avoid these things. Why wouldn't you want to use it? It's like sending a drum submix to a bus, you'd turn off the individual channels so you wouldn't be hearing them twice, just from the bus alone.
ARCADIOS
Post by ARCADIOS »
i am trying to find a way so that automatically to be cut when the same audio singal is coming back.
i have made my configuration though, and it is just the traditional way of cutting the mix so to hear only the singal that will be recorded in th sequencer.
but i would be very interested in having a safe audio switch... auto turn off.. when accidentally i forget the mix button on and huge distortion comes out of the monitors and break my ears :cry: :cry:
