pls help how 2 put pitch modifier on a "sample osc" in modular 2/3 + flexor 3 (if needed)
i can do it with a saw osc but with "sample osc" i dont know how
i want 2 have the same effect as like putting a pitch modulation on a simple saw/sine osc
hope u can helpppppppp coz i am building a nordwave on fl3 (not the poor nord xtc)
pitch modifier on a "sample osc" ?????? how?????
Re: pitch modifier on a "sample osc" ?????? how?????
from all the smart ppl here no one can help ?
- Ben Walker
Hi there,
sorry - didn't see your post before.
You can find an example of pitch mod on a sample oscillator in my Jaded800 patch.
Download it here:
http://www.modularsynth.co.uk/downloads.html
(or the smaller Jaded400)
and read about it here:
http://www.modularsynth.co.uk/patchpages/jaded800.html
Hope that helps,
Ben
Download it here:
Hope that helps,
Ben
10x 4 trying 2 help but there is no pitch modifier in your patch
i need 2 put pitch modifier on a sample osc !!!!!!
i can do it with saw osc but it cant be done with a sample osc so mybe the is a way...?
someone plsssssss help
- Ben Walker
Maybe I'm misunderstanding you, but there is a pitch modifier on the same osc. It's fed by a 4-way mixer.HYPERIONIX wrote:10x 4 trying 2 help but there is no pitch modifier in your patch
Here's a quote from the page
BenFollowing this comes the Pitch Mod section. Here we have an ADSR B envelope, a 2-way mixer and a 4-way mixer. Unlike the other sections, here the modulation can be carried out by a mix of both LFO's simultaneously, rather than 1 or the other, so here we have a 2-way mixer to mix the signals from the LFO's, followed by a four way mixer to mix the output of the LFO mixer, the Amp, Velocity and inverted Envelope signals.
sorry dosn't help... but 10x anyway
- Ben Walker
My Scope system is boxed up at the moment - just moved back home after 3 months of building work. Once I'm up and running, I'll knock up a small patch to show you.HYPERIONIX wrote:sorry dosn't help... but 10x anyway
Ben
ok man thank u i'll be waiting...
- Ben Walker
I've attached a very simple patch which has four presets.
The first two demonstrate pitch modification of a sample osc being done by two different LFO's.
The second two demonstrate pitch modification of a sample osc being done by envelopes.
You'll need to either load the JD800 standalone sample set into the project window before you load the patch, or you can simply replace the samples with your own.
Hope this is what you're looking for.
Ben
Ben
- JadedBasic.rar
- (1.27 MiB) Downloaded 215 times
