Exactamente Brotha' Man Francis..............I am not concerned why either, but glad.
It's really noticable on the analog synths I pump into projects. The lows destroy my headsets so I use Shroomz CanControl and cut the lows a little bit.
Even my Blue Sky 8" Sub gets thick as tree sapp.
I don't even use the A16U live because I do not need all of the I/O's, and the Analog input is fine for use and can bypass the ADAT's.
The old analog I/O's on the cards was unacceptable actually,and so I sold all of my Analog 1U effects, now I regret that. The Line 6 Echo Pro is rare these days,and the Oberheim Echoplex Pro and DoD Spring reverb too.
One benefit is the rotary cabinet has mic'd mono outs that can be re routed into the XITE-1 and sounds marvellous, much better than the B2003's Leslie emulation. On the B2003 it sounds like someone stuffed the mic on the lower baffle inside of the wood.....
Close mic'd stuff is cool but the emulation has serious wobble and is rather difficult adjusting a proper balance. No biggie though, as I am probably the only user.
I think you will be a happy camper Francios.........
