Hi there,
I am selling my Cw Pulsar ll & SRB 15 Sharc DSP Expansion Board.
This also comes with Scope 3.1
Synths 'n' Sampler Pack
& The Samples Collection for CW STS Samples.
Price £800 for the lot,
Or may consider a swop.
Cheers
Paul
Re: Cw Pulsar ll & SRB 15 Sharc DSP Expansion Board
Pulsar 2 - £450
SRB - £550
£800 for the lot
SRB - £550
£800 for the lot
that is a interesting offer. pulsar2 z link means it will work with xite-1? is z link cable and adat cables are same?Paul T wrote:Pulsar 2 - £450
SRB - £550
£800 for the lot
thanks
1) where exactly did you read Z-Link?firubbi wrote:that is a interesting offer. pulsar2 z link means it will work with xite-1? is z link cable and adat cables are same?Paul T wrote:Pulsar 2 - £450 - SRB - £550 - £800 for the lot
2) why (or better : how?) should Z-Link mean "it will work with xite"? you don't intend to connect the xite Z-Link to the Z-Link port of a scope card, do you? you could fry 2 lunas as well, that's much cheaper...
3) adat and Z-Link cables are not the same
sorry the question will be does z link and adat works together.
thanks
thanks
if you mean "can I use z-link and adat ports found on a single pci board or a group of pci boards at the same time", then yes. there is no "either or".
from what I've heard this applies to xite, too.
as long as you put all I/O in your project and have all hooked peripherals in sync, they should work concurrently, as expected.
cool .. so xite has 34 mono ch.+2 aes total 34 ch.
no. it hasfirubbi wrote:cool .. so xite has 34 mono ch.+2 aes total 34 ch.
- 2x Mic In (Combo XLR that can be set to Instrument In, too)
- 2x Analog In/Out (Balanced)
- 2x AES/EBU In/Out
- 16x ADAT In/Out
- 16x Z-Link In/Out
that makes even 38 In an 36 Out
is the SRB board is type 2?
thanks
thanks
