Multidimentional Morphing Phaser
I was trying out the X-Y joystick morphing on the standard creamware phaser, and it was fun so i made it avaliable.
It is a standard effect device, so if you want to use it with MIDI you will need to use it in a midiiser or insert. The small knobs by the joystick are something to right click on to assign MIDI controllers to.
It works like other morphing devices (transplanet etc) there are 2 knobs for each parameter. but they can be assigned to either the X or Y axis of the "joystick"
Have fun! (low DSP use for a change
update
OOPS! fixed the extra non working phaser surface that pops up!
Fixed the link as Req by Atom, but did not check to see if it actually works in scope 4.0 yet
if i still have the project ill look in to updating it.
