i was using SFP5 since some days after its release.
i haveo to admit that i use the "old" ASIO1 source/dest modules (16 bit) because the new ASIO2 are (or they seems to me) 24 bits ony in Sonar 6.
http://forums.planetz.com/viewtopic.php?f=5&t=27569
and so they should be more resource demanding.
now, in relatively simple projects using kontakt3 and the freeware NI kore i experience CPU hogs and crackles.
occasional crackles are also heard during the mixdown in sonar6.
i used SFP4.5 for years without any single problem, except in VERY BIG projects (like a full GPO orchestra with more that 50 tracks), where i had to convert in audio some MIDI tracks.
is anyone experiencing the same?
should i definitely switch to 24 bit? in this case i'm pretty sure to get the DSP overload system since i usually directs a lot of separate tracks from sonar to SFP mixer... or this was what happened in SFP4.5
SFP5 crackles while SFP4.5 no ?
bosone
- garyb
- Moderator
Re: SFP5 crackles while SFP4.5 no ?
ASIO2 isn't that new...the bit depth is determined by the ASIO@ source module used. there's only one ASIO2dest choice.
i don't find ASIO2 to be super resource heavy, but i'm still in 4.5...i think you are the first with this problem. perhaps there's another issue...
bosone
as far i as tried, asio2 is seen only as 24 bits in sonar
anyway, i will try
anyway, i will try
bosone
switching to asio2 doesnt solve the crackle and CPU hogs problems for me...
