importing activation keys problems
ARCADIOS
Post by ARCADIOS »
1. sixstring activation key is not accepted. says invalid key. :-?
2. how can i load my other modules that i used to with oxe file?
3. there are some modules that ask for key, i then import the rgy file scope5 has sent, it says succesful.. but no module appears and when i try to reload it it asks again for key.
common scope :x :x :x
Re: importing activation keys problems
if you use oxe files, DO NOT use the dsp files that come with them. put the device and preset files in the proper folders and then see if you are prompted for missing dsp files. if you have already loaded dsp files from oxe files, then you should just start over. if it still doesn't work, let them know at S/C at the bug email address. man up.
"RC" at the end of a version name(like 5.0.0263 RC) indicates "release candidate", not the final version. it's beyond a beta, but there are still some details to be worked out before the true release version. afaik, the v5 rc is fully usable, however.
